I have 5-7 routers that was hijacked and I lost access to it. There routers was never backuped and have pretty big configuration. Is there a way to restore it’s configuration ?
If these routers have an lcd screen and if its not locked and you have physical access, you can maybe restore a previously saved configuration via the lcd screen.
Are there open winbox/web services at these devices? For example, if there the winbox service was open before, and after the hijacking it’s remaining open, you’ve got a chance to get the device back if there’s a vulnerable RouterOS version there. An attack vector depends on conditions there were before. So it’s interesting which of the management services were enabled then, and what has been changed since the attack. And the RouterOS version then and now.
At least it reminds you (and others) to always make backups and/or exports…
Do you have any idea (e.g. from logs) who was the attacker? Was it 188.92.74.189 that was active first week of may?
There’s a tool called Router Scan, which recently got the winbox exploit implemented. I think, you’d give it a try. Probably, this tool was used by someone to hijack your devices. And if RouterOS versions aren’t updated now, you have a chance.
I don’t know, but there’s the default setting to automatically send out the results to the server, so it has to be configured properly first. It’s just a tool that does its job. If you know of any vulns there, please tell us, so I won’t suggest it further.
Seems that Router Scan do not help, not sure I got correct router scan… It only shows that my hijacked routers has 6.41 and 6.40.6 versions… The main problem is that one of the hijacked routers is 250 km away from me, please any other advice welcome
Yes, I got this 2.60 Beta. Entered IPs, started scan (added port 8291 also), each router listed twice, detected ROS version, total results found 7, good results - 0. In the lines with port numbers 8291 is written status Can’t load main page. When trying to connect from winbox it still reports incorrect login / password…
It’s hard to tell if it’s the same version. If you tried that prerelease.7z contents, then there can be some restriction in the firewall rules or in the services. Btw, there’s no need to specify 8291 port: RS tries to use HTTP on these ports.
Yes, I tried with clear vulnerable router, this version is working and shows the admin password but not on the hijacked routers. Seems that they did something to close this exploit…
