i have installed r52n with a minipci-pci adapter in my pc, the hardware is found , but the windows driver recommended by mikrotik can’t recognize the card ,
after i manually install the driver , in device manager the card look well , but it can’t find any ap whatever using microsoft’s wifi configuration in windows or using
atheros’s utility shipped with driver , can anyone help me , thank you in advance !
did you look here? http://www.atheros.cz/
of course , i have mentioned in my message , i have test the driver download from the atheros.cz , the driver can only install by manully (by force) , maybe the VID/DID is not
include in INF file , the driver seemed install correctly , but can’t work indeed.
does anyone else use r52n in a pc , why not do a test
Was anyone ever successful installing the R52Hn miniPCI network adapter in a Windows machine? ![]()
-Steve
I’m running one in mine.
Better range than the R52 but I cannot get N speeds working.
Can you give details of how you got your card working?
I installed the drivers but XP says no driver installed when looking at the card via device manager.
The ONLY way I found was to FORCE it to install as an Atheros 922x card…
no way forcing r52hn in atheros.cz drivers.
searched in google a lot and no driver for windows.
anyone have this driver?
thx.
same driver for the r52n and r52hn.
I figured out my lack of N speed problem, enabled AES.
