Is there an answer about Chain
when use prerouting ???
and when use postrouting ???
thanks :smiley: :smiley: :smiley:
can’t say exactly !
it completely depends on your network configuration.
http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
input : packets coming to the router itself
output : packets going out from the router itself
forward : packets going through the router.
prerouting : before the router routes packets !
postrouting : after the router routes packets based on its routing table
thank you sir
