The simple portforward will not work for me
im forwarding an Ip from a pptp connection to a local ip on a NAT
very very simple
0 chain=srcnat action=masquerade src-address=0.0.0.0/0 out-interface=DSC
1 chain=dstnat action=dst-nat to-addresses=192.168.10.22 to-ports=3000
protocol=tcp dst-port=3000
# DST-ADDRESS PREF-SRC GATEWAY DISTAN
0 X S 0.0.0.0/0 DSC-local (Disabled)
1 A S 0.0.0.0/0 DSC
2 S 0.0.0.0/0 ether1 (not A - active)
3 ADC 10.50.5.192/26 10.50.5.201 bridge-local
4 A S 172.24.xxx.xxx/32 bridge-local ( just a route to get access to the pptp sserver)
5 ADC 192.168.10.0/24 192.168.10.2 br2
6 ADC 202.xxx.xxx/32 202.4.xxx.xxx DSC
port 3000 is just a webserver
When i try from an external computer i can connect to port 80 mikrotik graphs and stuff
but when i connect to :3000 via web it times out, But I SEE the Nat rules ticking away
I tried the packet sniffer and i didnt see anything apearing on the LAN
This is so simple i have never had this problem before, it seems so simple
I tried removing everything and re adding it still nothing…
