Is there any possible way to determine within a firewall chain the physical interface a packet entered IF that physical interface belongs to a bridge?
So far as I can tell by experimentation, this is impossible. The “in-interface” only matches the bridge interface.
Any ideas? Pointers?
Thanks!
look at ‘in-bridge-port’ and ‘out-bridge-port’
if not - check that /interface bridge settings set use-ip-firewall=yes
Fran66
3
Those options for some reason doesn’t work, can someone address this problem?
Chupaka
4
what version of ROS do you use?
