Is there anyway to enable BBR on Mikrotik CHR?
Hello Guys ,
I currently have two virtual servers . One is CentOS based and the other is Mikrotik CHR . I have OpenVPN server enabled on both . When clients connect , their speed was kind of similar before I enabled BBR on the CentOS machine . After enabing BBR on the CentOS machine , OpenVPN users on that server can reach 100 Mbps but the ones that are connected to Mikrotik CHR OpenVPN server , are getting 25 Mbps at best . I just wanted to know , is there a BBR option in Mikrotik CHR and if yes , How do we enable it so that OpenVPN users that are using TCP protocol can get better connection speed ?
Regards ,
You already asked this elsewhere. Stop posting the same thing twice.
But don’t you have enough wit to understand that if you google bbr mikrotik chr and the only result is your already opened (bumped) topic,
maybe there is a very specific reason?
Please stop spam.
duplicated post
http://forum.mikrotik.com/t/is-there-anyway-to-enable-bbr-on-mikrotik-chr/169738/1
