The biggest issue here, The real pain, is MT change in syntax, without any notice, between ros versions. We use autogenerated script to all our system, but is forced to have to manny versions. 1 to 3x. 1 to 4x 1 to 5 x etc, is ok, but when we need to have 10 different, to different 3.x versions, it is a pain.
I agree that small changes in syntax break everything. Each release, even a point release, requires careful testing of each and every script. It is a real pain.
Have you tried this on 5.21? I just tested and ROS does not like it, says that y is a bad command and it still prompts me for confirmation. /system reboot used to work but then at some point the confirmation was added and started to cause scripts to fail.
We are trying to completely automate the inbound testing, configuration, reboot cycling and firmware upgrade of routerboards. Much easier said than done when you need to repeatedly cycle boards, upgrade firmware etc. Especially when tools like FlashFig don’t work properly with the version of ROS that new boards come with (5.11). With hundreds of boards to configure, doing all of this manually is just impossible.
We would really prefer to use standard PXE boot and have a normal vmlinux boot image that we could run from rather than use FlashFig. Mostly because this is known to work well and it can be started at boot time so you don’t have to manually kick off the server. NetInstall is fine for a single board, but for mass production it is insufficient.
Anyway, so the only way that we were able to get /system reboot to work properly from a script import (/system script import blah) was:
Create a script from the script being imported that contains the /system reboot command
Then execute a /system script run command for the script that we created from the imported script
This does work and will bypass the confirmations.
Suggestion: When scripts are run from the import command, disable all confirmations.
We have tried many different ways to get /system upgrade to run from a script and nothing works. This requires manual execution due to confirmations. We have tried running from import script, run script and scheduled script. None works.
We would also like to be able to import password protected certificates (openvpn, ssl, etc), but there is no way to script the password field. Of course we would not ship out passwords to the certs once installed, but for mass production this also would be helpful.
So far our process has weeded out about 10-15% of incoming boards as defective directly from MT. The problems are either perpetual rebooting (seems like a boot loader failure of some type) and cannot be reset (since there is no serial access to the board), or bad NAND with failed blocks. 15% doa is really bad, but if we can catch them on inbound receipt, at least they don’t go out to customers and we can get replacements from the distributor rather than going through the incredibly slow RMA process.
Hi, that is not that much funny… I need any possible way of upgrading bootloader from script in a lot of RBs (similarly as DogHead wrote). For last week I was writing emails to your support and yesterday they wrote me, that upgrading bootloader is most likely impossible from script/scheduler/or whatever in ROS 5.21. And in scheduler just because, bootloader upgrade can by done after ROS upgrade, so after reboot, so put “/system make-me-a-coffee-and-cake” into a script which will run after that reboot makes sense, I guess…
P.
We figured out that the way to make reboot work was to import a script that created a script and added a scheduler event that was a minute or two later than when you ran the script. Also have it run on startup another script which disables the scheduler that runs the reboot. Really messy.
We do the same type of thing with system upgrade to get the bootloader updated. This works about 50% of the time. We can’t really trouble shoot it. Debug log and script log don’t give any clue about why it works sometimes and sometimes not.
Anyway, yes, you can reboot from scripts but not if you import them or run them from command line.
Yes you can sometimes run upgrade from script, but it only works about 50% and you can’t do it from an import or run from command line.
i know for sure that in 5.21 and 5.22 /system reboot and /system routerboard uppgrade if ran by script is non-interactive and does not require the press of ‘y’ to accept the changes. As these definitely where changed to work for API as API does not bode well with anything interactive and same way to work using scripting as that also is non-interactive environment.
edit: running script form command-line does invoke interactive mode.
