Is there Voltage Monitor in RB433AH?
If not how expensive is to have Voltage Monitor in one Routerboard?
This is a very important feature. I miss it even in Dude.
Yes it is there. Not yet in the RB433 though it should be in future production runs.
Tom
My 433AH doesn’t have the voltage monitor. Is this something new?
Do a “/system health print” and paste…
make sure you have v3.11 and the routerboard package is installed
OK.
[admin@MikroTik] /system health> print
fan-mode: auto
use-fan: main
active-fan: main
Normis: I will try the upgrade. I am on V3.9 now.
And after the upgrade to V3.11:
fan-mode: auto
use-fan: main
active-fan: auxiliary
voltage: 14.1
This unit is powered by a deep-cycle battery, and the battery voltage monitor on the charger shows the battery voltage at 14.1.
Thanks again, Normis. …and again, and again…
and thanks to Tom “roc-noc”.
Is there any oid for voltage? On rb333 works fine but on 433ah I can’t find the oid ![]()
iso.org.dod.internet.private.enterprises.mikrotik.mikrotikExperimentalModule.mtXRouterOs.mtxrHealth.8.0
dingsingo
I can’t walk the mtxrHealth.8.0 on the 433ah
(3.11)
C:\1\snmp>SNMPUTIL.EXE get 172.20.70.253 public .1.3.6.1.4.1.14988.1.1.3.8.0
Variable = .iso.org.dod.internet.private.enterprises.14988.1.1.3.8.0
Value = Integer32 116
C:\1\snmp>SNMPUTIL.EXE get 10.10.170.121 public .1.3.6.1.4.1.14988.1.1.3.8.0
Error: errorStatus=2, errorIndex=1
172.20.70.253 is rb333
10.10.170.121 is 433ah
snmp set and enablet of course
