Pretty newbie question… Here is the Routerboard screenshot:
Can i upgrade the firmware?
update RouterOS first, then you can upgrade firmware in System → Routerboard.
Regards
Bernd
Does my Routerboard support new versions?
Yes. Only unsupported devices so far are old RB1xx and RB5xx.
Does my router download fw from Mikrotik’s server directly?
Sent from my SM-G935W8 using Tapatalk
Upgrading RouterOS is done under System → Packages. Like Windows, or OS X on your PC / Mac.
The firmware you are looking at under System → RouterBoard is equivalent to the BIOS on your PC. That doesn’t get updated so often.
After you update RouterOS under System → Packages and reboot, it may or may not have a new RouterBoard firmware which you can then update under System → RouterBoard and reboot again.
