is this a hack ?
hi…
can anybody tell me what that means ?
01:14:52 radvd,warning neighbor fe80::2199:b006:96aa:b476 on eth2/hotspot uses other stateful configuration
thankx
gerd
Hi Gerd,
it means some one else is sending out ipv6-addresses in your network. as it looks like they came in from a hotspot, that is something you can discard or block it by some filters. but as long as nobody uses v6 in your network you should not worry about it.
it is definitely not a hacking attempt, more a misconfigured client.
thanks a lot thadem…
