is this correct /30 is 2 usable IP?
Hello
i have a two router one is edge router ubnt and one is rb1100ah i put /30 both router the packets is unreachable but if i put /24 it works hmmmmmm?
edge router ether3 192.168.95.2/30
mikrotik ether10 192.168.95.1/30
thanks
/30 has 2 useable ips (1 & 2) and you have used both of them on the routers. your system ip is no longer on that subnet. but /24 has more ip which include you system or device ip in the subnet. that is why it is unreachable in /30 and reachable in /24
Hello JP
thats why im wondering why the packets cant pass through if im using /30 and keep my head spinning of this. as my understanding /30 2 usable ip and it can use two routers to communicate as a gateway becasue i have another subnet defrent ip.
thanks
hello again jp
anyway it works now i put a wrong gateway for the nexthop.
thanks
Good!
