Is this max for Microtik?
Wireless link bonding, bridge, nv2, N, 5Ghz 40Mhz, 2km
750GL - 2 x SX — 2 x SX - 750GL
Is there anything more I could do to get more speed for this wireless backbone link?
thanks lots
M
Could you also upload a picture showing the signal strenth and the quality geted on EACH link please?
Thanks.
As requested -signal strength
thanks for the help.
A very nice setup, congratulations with the achieved speed!
Well, i would like more - What’s the draw of getting another 4 SXT antenna and bond them to existing infrastucture?
Do I look at double the speed again? Would I have to replace the 750GL with 1100AH for processing reason/ additonal VLan tagging on one site?
thanks lots
the cpu on the bonding router appears to be max, why not try a more powerful unit and see how your speeds go then? maybe a 951/2011. I’d imagine you may be able to squeeze a little more :smiley:
maybe in btest, as you can see those RB750GL are used to generate the traffic, in real traffic I don’t think they will hit 100%.
True - currently they 750GL hit 55% average while running btest on AH1100 - though, speed on bonding interface seems about the same…
it is good, my bonding has ~340mbps with regular SXT
