I am about to upgrade a network to managed switches to add vlans and needing 2 small switches that can pass one vlan trunk with 4 vlans on it. The had an ethernet run that was almost 700’ to another building and was having issues needless to say, luckily I was able to fit 2 switches into a large conduit opening that broke the run up into three 233’ runs which made it a reliable link to the other building. Here is a diagram, and will a POE injector at each building work ok and if you use POE does that port still support gigabit? Other than passing vlans no other functions will be used, do these units have any issues doing that?
Building 1
48 Port Switch
| 233’ Cat5
RB260GS
| 233’ Cat5
RB260GS
| 233’ Cat5
48 Port Switch
Building 2
Jason
