Is this possible?
We are changing our hosting provider and wondered if it is possible to have the radius server public-facing and drop the RB1100 and PPtPs links? We are using DMA Softlab’s Raduis Manager.
Current NW topology:
Proposed NW topology:
I changed the IP in the radius entry on an RB750 (and every where else the private radius IP was listed) at a remote site to the public IP of the radius server but am unable to authenticate via our login page. The message is Radius server is not responding. The radius server can be pinged and I turned its firewall off during testing. Before I spend any more time on this I thought I’d ask your opinions in case what I am trying to acheive is not possible.
Many thanks.
Have you added a clients.conf on the radius server to allow it to authenticate NAS devices coming in from the internet?
Its totally possible, as thats how we do it , although we are now using PPTP and RB;s for the very purpose of remote management ( but Radius traffic still comes over the net)
I believe that the clients.conf is modified by our radius manager software when a NAS is added. Here’s the contents - 92.18.96.238 is the RB I’m testing from.
client 87.114.73.107 {
secret = yamahar6
shortname = BSC Winton
client 92.18.96.238 {
secret = yamahar6
shortname = SB TEST
Have you opened up ports 1812 - 1813 on the Radius servers firewall now that clients will be coming in over the internet?
What is the radius server reporting - assuming its Freeradius, you can do free radius -X to see the debug screen
Ports 1812-1813 are open on the Radius servers firewall.
radiusd -X:
Listening on authentication address * port 1812
Listening on accounting address * port 1813
Listening on command file /usr/local/var/run/radiusd/radiusd.sock
Listening on proxy address * port 1814
Ready to process requests.
I’m testing on a dynamic IP so the client.conf has changed to:
secret = yamahar6
client 92.18.99.72 {
secret = yamahar6
shortname = SB TEST
When I try to login I get the following from the radiusd -X debug screen. The user apears to authenticate ok (shown in bold) but the NAS is not recognised (shown in red):
port = 1812
type = “auth”
secret = “testing123”
response_window = 20
max_outstanding = 65536
require_message_authenticator = no
zombie_period = 40
status_check = “status-server”
ping_interval = 30
check_interval = 30
num_answers_to_alive = 3
num_pings_to_alive = 3
revive_interval = 120
status_check_timeout = 4
irt = 2
mrt = 16
mrc = 5
mrd = 30
home_server_pool my_auth_failover {
type = fail-over
home_server = localhost
realm example.com {
auth_pool = my_auth_failover
realm LOCAL {
radiusd: #### Loading Clients ####
secret = “yamahar6”
shortname = “BSC”
secret = “yamahar6”
shortname = “sbtest”
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_exec
Module: Instantiating exec
exec {
wait = no
input_pairs = “request”
shell_escape = yes
Module: Linked to module rlm_expr
Module: Instantiating expr
Module: Linked to module rlm_expiration
Module: Instantiating expiration
expiration {
reply-message = “Password Has Expired "
Module: Linked to module rlm_logintime
Module: Instantiating logintime
logintime {
reply-message = “You are calling outside your allowed timespan "
minimum-timeout = 60
radiusd: #### Loading Virtual Servers ####
server inner-tunnel {
modules {
Module: Checking authenticate {…} for more modules to load
Module: Linked to module rlm_pap
Module: Instantiating pap
pap {
encryption_scheme = “auto”
auto_header = no
Module: Linked to module rlm_chap
Module: Instantiating chap
Module: Linked to module rlm_mschap
Module: Instantiating mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = no
Module: Linked to module rlm_unix
Module: Instantiating unix
unix {
radwtmp = “/usr/local/var/log/radius/radwtmp”
Module: Linked to module rlm_eap
Module: Instantiating eap
eap {
default_eap_type = “md5”
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 4096
Module: Linked to sub-module rlm_eap_md5
Module: Instantiating eap-md5
Module: Linked to sub-module rlm_eap_leap
Module: Instantiating eap-leap
Module: Linked to sub-module rlm_eap_gtc
Module: Instantiating eap-gtc
gtc {
challenge = “Password: "
auth_type = “PAP”
Module: Linked to sub-module rlm_eap_tls
Module: Instantiating eap-tls
tls {
rsa_key_exchange = no
dh_key_exchange = yes
rsa_key_length = 512
dh_key_length = 512
verify_depth = 0
pem_file_type = yes
private_key_file = “/usr/local/etc/raddb/certs/server.pem”
certificate_file = “/usr/local/etc/raddb/certs/server.pem”
CA_file = “/usr/local/etc/raddb/certs/ca.pem”
private_key_password = “whatever”
dh_file = “/usr/local/etc/raddb/certs/dh”
random_file = “/usr/local/etc/raddb/certs/random”
fragment_size = 1024
include_length = yes
check_crl = no
cipher_list = “DEFAULT”
make_cert_command = “/usr/local/etc/raddb/certs/bootstrap”
cache {
enable = no
lifetime = 24
max_entries = 255
Module: Linked to sub-module rlm_eap_ttls
Module: Instantiating eap-ttls
ttls {
copy_request_to_tunnel = no
use_tunneled_reply = no
virtual_server = “inner-tunnel”
Module: Linked to sub-module rlm_eap_peap
Module: Instantiating eap-peap
peap {
default_eap_type = “mschapv2”
proxy_tunneled_request_as_eap = yes
Module: Linked to sub-module rlm_eap_mschapv2
Module: Instantiating eap-mschapv2
mschapv2 {
Module: Checking authorize {…} for more modules to load
Module: Linked to module rlm_realm
Module: Instantiating suffix
realm suffix {
format = “suffix”
delimiter = “@”
ignore_default = no
ignore_null = no
Module: Linked to module rlm_files
Module: Instantiating files
files {
usersfile = “/usr/local/etc/raddb/users”
acctusersfile = “/usr/local/etc/raddb/acct_users”
preproxy_usersfile = “/usr/local/etc/raddb/preproxy_users”
compat = “no”
Module: Checking session {…} for more modules to load
Module: Linked to module rlm_radutmp
Module: Instantiating radutmp
radutmp {
filename = “/usr/local/var/log/radius/radutmp”
username = “%{User-Name}”
case_sensitive = yes
check_with_nas = yes
perm = 384
callerid = yes
Module: Checking post-proxy {…} for more modules to load
Module: Checking post-auth {…} for more modules to load
Module: Linked to module rlm_attr_filter
Module: Instantiating attr_filter.access_reject
attr_filter attr_filter.access_reject {
attrsfile = “/usr/local/etc/raddb/attrs.access_reject”
key = “%{User-Name}”
} # modules
} # server
server {
modules {
Module: Linked to module rlm_preprocess
Module: Instantiating preprocess
preprocess {
huntgroups = “/usr/local/etc/raddb/huntgroups”
hints = “/usr/local/etc/raddb/hints”
with_ascend_hack = no
ascend_channels_per_line = 23
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
Module: Linked to module rlm_sql
Module: Instantiating sql
sql {
driver = “rlm_sql_mysql”
server = “localhost”
port = “”
login = “radius”
password = “radius123”
radius_db = “radius”
read_groups = yes
sqltrace = no
sqltracefile = “/usr/local/var/log/radius/sqltrace.sql”
readclients = no
deletestalesessions = yes
num_sql_socks = 5
lifetime = 0
max_queries = 0
sql_user_name = “%{User-Name}”
default_user_profile = “”
nas_query = “SELECT id, nasname, shortname, type, secret FROM nas”
authorize_check_query = “SELECT id, username, attribute, value, op FROM radcheck WHERE username = ‘%{SQL-User-Name}’ ORDER BY id”
authorize_reply_query = “SELECT id, username, attribute, value, op FROM radreply WHERE username = ‘%{SQL-User-Name}’ ORDER BY id”
authorize_group_check_query = “SELECT id, groupname, attribute, Value, op FROM radgroupcheck WHERE groupname = ‘%{Sql-Group}’ ORDER BY id”
authorize_group_reply_query = “SELECT id, groupname, attribute, value, op FROM radgroupreply WHERE groupname = ‘%{Sql-Group}’ ORDER BY id”
accounting_onoff_query = " UPDATE radacct SET acctstoptime = ‘%S’, acctsessiontime = unix_timestamp(‘%S’) - unix_timestamp(acctstarttime), acctterminatecause = ‘%{Acct-Terminate-Cause}’, acctstopdelay = %{%{Acct-Delay-Time}:-0} WHERE acctstoptime IS NULL AND nasipaddress = ‘%{NAS-IP-Address}’ AND acctstarttime <= ‘%S’”
accounting_update_query = " UPDATE radacct SET framedipaddress = ‘%{Framed-IP-Address}’, acctsessiontime = ‘%{Acct-Session-Time}’, acctinputoctets = ‘%{%{Acct-Input-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Input-Octets}:-0}’, acctoutputoctets = ‘%{%{Acct-Output-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Output-Octets}:-0}’ WHERE acctsessionid = ‘%{Acct-Session-Id}’ AND username = ‘%{SQL-User-Name}’ AND nasipaddress = ‘%{NAS-IP-Address}’”
accounting_update_query_alt = " INSERT INTO radacct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctsessiontime, acctauthentic, connectinfo_start, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, servicetype, framedprotocol, framedipaddress, acctstartdelay, xascendsessionsvrkey) VALUES (‘%{Acct-Session-Id}’, ‘%{Acct-Unique-Session-Id}’, ‘%{SQL-User-Name}’, ‘%{Realm}’, ‘%{NAS-IP-Address}’, ‘%{NAS-Port}’, ‘%{NAS-Port-Type}’, DATE_SUB(‘%S’, INTERVAL (%{%{Acct-Session-Time}:-0} + %{%{Acct-Delay-Time}:-0}) SECOND), ‘%{Acct-Session-Time}’, ‘%{Acct-Authentic}’, ‘’, ‘%{%{Acct-Input-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Input-Octets}:-0}’, ‘%{%{Acct-Output-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Output-Octets}:-0}’, ‘%{Called-Station-Id}’, ‘%{Calling-Station-Id}’, ‘%{Service-Type}’, ‘%{Framed-Protocol}’, ‘%{Framed-IP-Address}’, ‘0’, ‘%{X-Ascend-Session-Svr-Key}’)”
accounting_start_query = " INSERT INTO radacct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctstoptime, acctsessiontime, acctauthentic, connectinfo_start, connectinfo_stop, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, acctterminatecause, servicetype, framedprotocol, framedipaddress, acctstartdelay, acctstopdelay, xascendsessionsvrkey) VALUES (‘%{Acct-Session-Id}’, ‘%{Acct-Unique-Session-Id}’, ‘%{SQL-User-Name}’, ‘%{Realm}’, ‘%{NAS-IP-Address}’, ‘%{NAS-Port}’, ‘%{NAS-Port-Type}’, ‘%S’, NULL, ‘0’, ‘%{Acct-Authentic}’, ‘%{Connect-Info}’, ‘’, ‘0’, ‘0’, ‘%{Called-Station-Id}’, ‘%{Calling-Station-Id}’, ‘’, ‘%{Service-Type}’, ‘%{Framed-Protocol}’, ‘%{Framed-IP-Address}’, ‘%{%{Acct-Delay-Time}:-0}’, ‘0’, ‘%{X-Ascend-Session-Svr-Key}’)"
accounting_start_query_alt = " UPDATE radacct SET acctstarttime = ‘%S’, acctstartdelay = ‘%{%{Acct-Delay-Time}:-0}’, connectinfo_start = ‘%{Connect-Info}’ WHERE acctsessionid = ‘%{Acct-Session-Id}’ AND username = ‘%{SQL-User-Name}’ AND nasipaddress = ‘%{NAS-IP-Address}’"
accounting_stop_query = " UPDATE radacct SET acctstoptime = ‘%S’, acctsessiontime = ‘%{Acct-Session-Time}’, acctinputoctets = ‘%{%{Acct-Input-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Input-Octets}:-0}’, acctoutputoctets = ‘%{%{Acct-Output-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Output-Octets}:-0}’, acctterminatecause = ‘%{Acct-Terminate-Cause}’, acctstopdelay = ‘%{%{Acct-Delay-Time}:-0}’, connectinfo_stop = ‘%{Connect-Info}’ WHERE acctsessionid = ‘%{Acct-Session-Id}’ AND username = ‘%{SQL-User-Name}’ AND nasipaddress = ‘%{NAS-IP-Address}’"
accounting_stop_query_alt = " INSERT INTO radacct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctstoptime, acctsessiontime, acctauthentic, connectinfo_start, connectinfo_stop, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, acctterminatecause, servicetype, framedprotocol, framedipaddress, acctstartdelay, acctstopdelay) VALUES (‘%{Acct-Session-Id}’, ‘%{Acct-Unique-Session-Id}’, ‘%{SQL-User-Name}’, ‘%{Realm}’, ‘%{NAS-IP-Address}’, ‘%{NAS-Port}’, ‘%{NAS-Port-Type}’, DATE_SUB(‘%S’, INTERVAL (%{%{Acct-Session-Time}:-0} + %{%{Acct-Delay-Time}:-0}) SECOND), ‘%S’, ‘%{Acct-Session-Time}’, ‘%{Acct-Authentic}’, ‘’, ‘%{Connect-Info}’, ‘%{%{Acct-Input-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Input-Octets}:-0}’, ‘%{%{Acct-Output-Gigawords}:-0}’ << 32 | ‘%{%{Acct-Output-Octets}:-0}’, ‘%{Called-Station-Id}’, ‘%{Calling-Station-Id}’, ‘%{Acct-Terminate-Cause}’, ‘%{Service-Type}’, ‘%{Framed-Protocol}’, ‘%{Framed-IP-Address}’, ‘0’, ‘%{%{Acct-Delay-Time}:-0}’)"
group_membership_query = “SELECT groupname FROM radusergroup WHERE username = ‘%{SQL-User-Name}’ ORDER BY priority”
connect_failure_retry_delay = 60
simul_count_query = "SELECT COUNT() FROM radacct WHERE username = ‘%{SQL-User-Name}’ AND acctstoptime IS NULL"
simul_verify_query = “SELECT radacctid, acctsessionid, username, nasipaddress, nasportid, framedipaddress, callingstationid, framedprotocol FROM radacct WHERE username = ‘%{SQL-User-Name}’ AND acctstoptime IS NULL”
postauth_query = “INSERT INTO radpostauth (username, pass, reply, authdate) VALUES ( ‘%{User-Name}’, ‘%{%{User-Password}:-%{Chap-Password}}’, ‘%{reply:Packet-Type}’, ‘%S’)”
safe-characters = “@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /”
rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
rlm_sql (sql): Attempting to connect to radius@localhost:/radius
rlm_sql (sql): starting 0
rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
rlm_sql_mysql: Starting connect to MySQL server for #0
rlm_sql (sql): Connected new DB handle, #0
rlm_sql (sql): starting 1
rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
rlm_sql_mysql: Starting connect to MySQL server for #1
rlm_sql (sql): Connected new DB handle, #1
rlm_sql (sql): starting 2
rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
rlm_sql_mysql: Starting connect to MySQL server for #2
rlm_sql (sql): Connected new DB handle, #2
rlm_sql (sql): starting 3
rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
rlm_sql_mysql: Starting connect to MySQL server for #3
rlm_sql (sql): Connected new DB handle, #3
rlm_sql (sql): starting 4
rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
rlm_sql_mysql: Starting connect to MySQL server for #4
rlm_sql (sql): Connected new DB handle, #4
Module: Checking preacct {…} for more modules to load
Module: Linked to module rlm_acct_unique
Module: Instantiating acct_unique
acct_unique {
key = “User-Name, Acct-Session-Id, NAS-IP-Address, Client-IP-Address, NAS-Port”
Module: Checking accounting {…} for more modules to load
Module: Instantiating attr_filter.accounting_response
attr_filter attr_filter.accounting_response {
attrsfile = “/usr/local/etc/raddb/attrs.accounting_response”
} # modules
} # server
radiusd: #### Opening IP addresses and Ports ####
listen {
type = “auth”
ipaddr = *
port = 0
listen {
type = “acct”
ipaddr = *
port = 0
listen {
type = “control”
listen {
socket = “/usr/local/var/run/radiusd/radiusd.sock”
rad_recv: Access-Request packet from host 92.18.99.72 port 62077, id=15, length=205
NAS-Port-Type = Wireless-802.11
Calling-Station-Id = “00:1E:90:4A:3E:E4”
Called-Station-Id = “hotspot1”
NAS-Port-Id = “ether2-local-master”
User-Name = “test”
NAS-Port = 2159017988
Acct-Session-Id = “80b00004”
Framed-IP-Address = 192.10.0.254
Mikrotik-Host-IP = 192.10.0.254
CHAP-Challenge = 0x89abd3b510064c16e544fd7d80809dc9
CHAP-Password = 0xeb01fae29ab910de3b959a77fec396ef89
Service-Type = Login-User
WISPr-Logoff-URL = “http://192.10.0.1/logout
NAS-Identifier = “sbtest”
NAS-IP-Address = 192.168.1.64
± entering group authorize {…}
++[preprocess] returns ok
[chap] Setting ‘Auth-Type := CHAP’
++[chap] returns ok
++[mschap] returns noop
[suffix] No ‘@’ in User-Name = “test”, looking up realm NULL
[suffix] No such realm “NULL”
++[suffix] returns noop
[eap] No EAP-Message, not doing EAP
++[eap] returns noop
[files] users: Matched entry DEFAULT at line 50
[files] expand: /usr/local/bin/rmauth “%{NAS-IP-Address}” “%{User-Name}” “%{Calling-Station-Id}” → /usr/local/bin/rmauth “192.168.1.64” “test” “00:1E:90:4A:3E:E4”
++[files] returns ok
[sql] expand: %{User-Name} → test
[sql] sql_set_user escaped user → ‘test’
rlm_sql (sql): Reserving sql socket id: 4
[sql] expand: SELECT id, username, attribute, value, op FROM radcheck WHERE username = ‘%{SQL-User-Name}’ ORDER BY id → SELECT id, username, attribute, value, op FROM radcheck WHERE username = ‘test’ ORDER BY id
[sql] User found in radcheck table
[sql] expand: SELECT id, username, attribute, value, op FROM radreply WHERE username = ‘%{SQL-User-Name}’ ORDER BY id → SELECT id, username, attribute, value, op FROM radreply WHERE username = ‘test’ ORDER BY id
[sql] expand: SELECT groupname FROM radusergroup WHERE username = ‘%{SQL-User-Name}’ ORDER BY priority → SELECT groupname FROM radusergroup WHERE username = ‘test’ ORDER BY priority
rlm_sql (sql): Released sql socket id: 4
++[sql] returns ok
++[expiration] returns noop
++[logintime] returns noop
[pap] Found existing Auth-Type, not changing it.
++[pap] returns noop
Found Auth-Type = CHAP
± entering group CHAP {…}
[chap] login attempt by “test” with CHAP password
[chap] Using clear text password “sgb71164” for user test authentication.
[chap] chap user test authenticated succesfully
++[chap] returns ok
± entering group session {…}
[sql] expand: SELECT COUNT(
) FROM radacct WHERE username = ‘%{SQL-User-Name}’ AND acctstoptime IS NULL → SELECT COUNT(*) FROM radacct WHERE username = ‘test’ AND acctstoptime IS NULL
rlm_sql (sql): Reserving sql socket id: 3
rlm_sql (sql): Released sql socket id: 3
++[sql] returns ok
± entering group post-auth {…}
Exec-Program output: Reply-Message=“NAS not found!”
Exec-Program-Wait: value-pairs: Reply-Message=“NAS not found!”
Exec-Program: returned: 1
[exec] Login incorrect (external check said so)
++[exec] returns reject
Using Post-Auth-Type Reject
± entering group REJECT {…}
[attr_filter.access_reject] expand: %{User-Name} → test
attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] returns updated
Delaying reject of request 0 for 1 seconds
Going to the next request
Waking up in 0.9 seconds.
Waiting to send Access-Reject to client sbtest port 62077 - ID: 15
Waking up in 0.6 seconds.
Waking up in 0.3 seconds.
Sending delayed reject for request 0
**Sending Access-Reject of id 15 to 92.18.99.72 port 62077
Reply-Message = “NAS not found!”**Waking up in 4.9 seconds.
Cleaning up request 0 ID 15 with timestamp +12
Radius.log entries:
Wed Jan 11 18:36:17 2012 : Error: Ignoring request to accounting address * port 1813 from unknown client 92.18.99.72 port 56449Wed Jan 11 18:54:27 2012 : Info: Exiting normally.
Wed Jan 11 18:54:31 2012 : Info: Loaded virtual server inner-tunnel
Wed Jan 11 18:54:31 2012 : Info: rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
Wed Jan 11 18:54:31 2012 : Info: rlm_sql (sql): Attempting to connect to radius@localhost:/radius
Wed Jan 11 18:54:31 2012 : Info: rlm_sql_mysql: Starting connect to MySQL server for #0
Wed Jan 11 18:54:31 2012 : Info: rlm_sql_mysql: Starting connect to MySQL server for #1
Wed Jan 11 18:54:31 2012 : Info: rlm_sql_mysql: Starting connect to MySQL server for #2
Wed Jan 11 18:54:31 2012 : Info: rlm_sql_mysql: Starting connect to MySQL server for #3
Wed Jan 11 18:54:31 2012 : Info: rlm_sql_mysql: Starting connect to MySQL server for #4
Wed Jan 11 18:54:31 2012 : Info: Ready to process requests.
Wed Jan 11 18:54:39 2012 : Info: Exiting normally.
hello is there a tutorial in your Current Setup? i would like to learn your diagram.. can you send me jizzner@gmail.com .. thanks
