is this RouterOS error!
I setup multiple IP addresses on a WAN interface (my route is a CCR1036-12G-4S). after I done the job, only about 10% of the IP is active, other IP can’t ping from outside network(Internet). when I disable then enable the IP from Winbox, that IP will active again, but they will inactive after cup of hours. is this RouterOS error? or have a right way do it?
Thanks!
can you show the output of
/ip address print
yes, all ip address shows up.
please show us that output :smiley:
admin@MikroTik] > /ip address print
ADDRESS NETWORK INTE...
0 X ;;; default configuration
192.168.88.1/24 192.168.88.0 bridge1
1 192.168.6.2/24 192.168.6.0 ether11
2 X 192.168.2.2/24 192.168.2.0 ether7
3 X 192.168.0.2/24 192.168.0.0 ether5
4 X 192.168.168.2/24 192.168.168.0 ether12
5 X xxx.x38.59.92/29 xxx.x38.59.88 WAN1
6 X xxx.x38.59.93/29 xxx.x38.59.88 WAN1
7 X xxx.x38.59.94/29 xxx.x38.59.88 WAN1
8 192.168.3.2/24 192.168.3.0 ether8
9 xxx.x5.x0.68/24 xxx.x5.x0.0 WAN2
10 xxx.x5.x0.2/24 xxx.x5.x0.0 WAN2
11 192.168.3.254/24 192.168.3.0 ether8
12 xxx.x5.x0.70/24 xxx.x5.x0.0 WAN2
13 xxx.x5.x0.71/24 xxx.x5.x0.0 WAN2
14 xxx.x5.x0.72/24 xxx.x5.x0.0 WAN2
15 xxx.x5.x0.73/24 xxx.x5.x0.0 WAN2
16 xxx.x5.x0.74/24 xxx.x5.x0.0 WAN2
17 xxx.x5.x0.75/24 xxx.x5.x0.0 WAN2
18 xxx.x5.x0.76/24 xxx.x5.x0.0 WAN2
19 xxx.x5.x0.77/24 xxx.x5.x0.0 WAN2
20 xxx.x5.x0.78/24 xxx.x5.x0.0 WAN2
21 xxx.x5.x0.79/24 xxx.x5.x0.0 WAN2
[admin
I just want setup multiple IP addresses NAT to my inside multiple hosts.
First, I singed the public IPs on a WAN interface. But only one IP (Pref. source) can be ping from outside. Do we have a way to turn on all of them?
Then, I setup the firewall NAT multiple public IP to my multiple LAN IP.
The result is only part of them work.
Thanks for help!!!
