is this setup OK
Can I have to interfaces wlan1 and wlan2 with same essid added as ports to a bridge with ip 10.0.61.1 masquerade hotspot network. I have two sector antennas attached to wlan1 and wlan2.
Can sombody confirm it is this OK for outdoor deployment.
Thanks in advance.
Alex
Yes you can. Depends on what you’re trying to achieve. If roaming for clients, also set them to the same frequency.
Well, the idea is to have two channels on one AP, lets say 1 and 11 to unload the traffic from one channel and improve performance.
Thank you
Alex
I use the same configuration and it works fine.
