Thanks, i’ve opened a support ticket. I think it’s probably (1)
I am able to SSH on my vlan 2005 tagged interface.
But it won’t let me connect if i want to use webfig or winbox. So maybe there’s a bug preventing those services from running on top of a vlan interface.
I have simplified the config to just have bridge br_lan and vlan interface, and nothing else :
# 2025-12-03 12:21:32 by RouterOS 7.20.6
# software id = XXXX-XXXX
# model = RB5009UG+S+
# serial number = XXXXX
add admin-mac=04:F4:1C:61:4D:88 auto-mac=no name=br_lan vlan-filtering=yes
set [ find default-name=ether1 ] l2mtu=1596
set [ find default-name=ether2 ] l2mtu=1596
set [ find default-name=ether3 ] l2mtu=1596
set [ find default-name=ether4 ] l2mtu=1596
set [ find default-name=ether5 ] l2mtu=1596
set [ find default-name=ether6 ] l2mtu=1596
set [ find default-name=ether7 ] l2mtu=1596
set [ find default-name=ether8 ] comment=WAN l2mtu=1596
set [ find default-name=sfp-sfpplus1 ] disabled=yes l2mtu=1596
/interface pppoe-client
add add-default-route=yes comment="WAN via PPPoE" interface=ether8 name=pppoe-out1 user=user@notyetactive.com
/interface vlan
add comment=v2005-GW interface=br_lan name=v2005 vlan-id=2005
add comment=defconf name=WAN
add comment=defconf name=LAN
/disk settings
set auto-media-interface=*B auto-media-sharing=yes auto-smb-sharing=yes
add bridge=br_lan interface=ether2
add bridge=br_lan interface=ether3
add bridge=br_lan interface=ether4
add bridge=br_lan interface=ether5
add bridge=br_lan interface=ether6
add bridge=br_lan interface=ether7
add bridge=br_lan interface=ether1
add bridge=br_lan interface=sfp-sfpplus1
/interface bridge vlan
add bridge=br_lan tagged=br_lan,ether7,ether6,ether5,ether4,ether3,ether2,ether1,sfp-sfpplus1 vlan-ids=2005
add comment=WAN interface=ether8 list=WAN
add interface=br_lan list=LAN
add interface=v2005 list=LAN
add comment=WAN interface=pppoe-out1 list=WAN
add interface=ether1 list=LAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=sfp-sfpplus1 list=LAN
add address=10.8.99.240/24 interface=br_lan network=10.8.99.0
add address=10.8.5.240/24 interface=v2005 network=10.8.5.0
/ip dhcp-client
# Interface not active
add comment="WAN via DHCP" default-route-tables=main interface=ether8
set allow-remote-requests=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat in-interface-list=WAN
/ip smb shares
set [ find default=yes ] directory=/pub
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/tool mac-server
/tool mac-server mac-winbox
