Hi Guys,
I hope someone can help out I have a hotspot network set up 100.100.100.1 and I have a server app running on it 100.100.100.100 is there a way only bypassed users can access this and block everyone else on the hotspot side?
Hi Guys,
Make a new VirtualAP on a separate SSID, and a separate subnet.
Move the server to that subnet.
Put a forward rule in the firewall rule list.
When you really don’t want to change the address, you can do the same thing with a bridge.
(new Virtual AP for only the server, and both in a bridge with filter rule)
Thanks but I dont follow how do I give bypassed users access? Also this is connected away from the main router via a switch also on the switch is a hot spot ap
