Hello there,
I will try to explain situation, best I can.
I am no expert, so I am writing here in hope that someone can actually help me with this.
In my setup I have “main” Mikrotik router with static(WAN) IP address.
Around ten remote Mikrotik routers are connected to main one with EOIP tunnel and OVPN.
All this EOIP connections are bridged together in one big LAN network.
Behind each Mikrotik router is a linux server, and I use techniques described above to connect them all together in LAN network.
However I have PPTP connection from user which needs to access one server inside LAN network and I need to isolate him from others.
LAN network : 10.1.1.1/8
Pptp user uses static local IP address : 10.30.0.1.
Servers IP he needs to have communication is on ip : 10.1.70.1
I need to allow pptp user to access IP address of this single server (10.1.70.1) and isolate him from all other IP addresses within LAN network…
How can I achieve that?
Thank you!
