Isolate two bridges(subnets) firewall
Hello.
Why “drop forward” doesnt block connection between bridges(subnets), anyway I can ping each other? It blocks WAN(NAT), but doesnt block inner connection between subnets. Firmware the newest, router ax2. I have tried different options, but just left most primitive, just to understand where is the problem.
Config:
# 2023-10-13 22:08:39 by RouterOS 7.11.2
# model = C52iG-5HaxD2HaxD
add admin-mac=B6:A7:6A:0F:36:6C auto-mac=no comment=LAN name=bridge1
add admin-mac=EE:BD:94:AC:2B:0F auto-mac=no comment=LAN-WIFI name=bridge2
add name=LAN
add name=dhcp_pool0 ranges=10.1.0.200-10.1.0.254
add address-pool=dhcp_pool0 interface=bridge1 lease-time=1h name=dhcp1
add bridge=bridge2 interface=ether5
add disabled=yes interface=bridge1 list=LAN
add disabled=yes interface=bridge2 list=LAN
add address=10.1.0.1/24 interface=bridge1 network=10.1.0.0
add address=10.2.0.1/24 interface=bridge2 network=10.2.0.0
/ip dhcp-client
add interface=ether1
add address=10.1.0.0/24 dns-server=10.1.0.1 gateway=10.1.0.1
set allow-remote-requests=yes servers=1.1.1.1
add action=drop chain=forward connection-state=""
Because your drop rule has connection-state=“” … but no connection state is equal empty string and hence no packet matches the rule. Setting something to empty string is not the same as not setting it.
Unset the property entirely (if using GUI, click the up-arrow so that it “folds”).
As said before I have tried everything and just forgot to remove field of states. Anyway ping goes between bridge1 and bridge2.
Reply from 10.2.0.1: bytes=32 time<1ms TTL=64
Ping statistics for 10.2.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Pinging router’s “non-native” address is actually handled by “chain=input” just like if pinging “native” address. And don’t go into “but that’s not right” argument, that’s the way it is and has been since forever.
Im here not to arguing but to understand where is the problem because before to write here I have tried to config according to manual/video, where bridge blocking was in forward drop.
Can you show exactly rule how to block bridge connection? Or can you link me to article where I can to read it.
Only one Firewall filter entry is visible from your copied configuration. Why? Where are the other rolls?
To isolate access to two different Brides, you must first use “default rules”, where you will also create the necessary entries.
I would recommend using the following method -
{Input Chain}
add action=accept chain=input in-interface-list=LAN
add action=drop chain=input comment="drop all else"
{forward chain}
add action=accept chain=forward comment="allow internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="allow port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="drop all else"
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface-list=WAN
Local_Lan=(your local IP address Bridge1)
Local_Lan2=(your local IP address Bridge2)
LAN= Bridge1
LAN2-=Bridge2
This rule - add action=accept chain=forward comment=“allow internet traffic” in-interface-list=LAN out-interface-list=WAN
=is responsible for ensuring that, for example, “Bridge1” has access to the Internet.
If you create another roll for “Bridge2”, then you will write accordingly -
→ add action=accept chain=forward comment=“allow internet traffic” in-interface-list=LAN2 out-interface-list=WAN
In this configuration, both Bridges will be isolated. If there is a need, for example, to access from Bridge1 to Bridge2, then you will have to create an additional rule=
add action=accept chain=forward comment=Lan-Access dst-address-list=Local-LAN2 src-address-list=Local-LAN…
As I wrote: your issue is not about blocking traffic between two bridges, it’s about (IMO cosmetic) issue of connecting router’s “non-native” address. To verify that your forward filter rule actually does the job, you have to use two devices, connected to different bridges, and try ping (or any other traffic) between those.
The basic packet flow is this: router receives packet, it checks if DST NAT needs to be performed (if yes, dst-address and optionally dst-port get replaced). Then it inspects dst-address (in case of DST NATed packets again). If (the new) dst-address matches any of router’s own addresses (ingress interface doesn’t matter), then packet is handled by chain=input. The rest of packets (which will eventually egress router via another L3 interface) are handled by chain=forward. Every packet is only handled by one of basic chains (forward, input or output - this one handles packets originating from router itself).
Now, if you want to block the non-native connectivity to router, you can add something like this:
add chain=input action=drop dst-address=10.1.0.1 in-interface=!bridge1
add chain=input action=drop dst-address=10.2.0.1 in-interface=!bridge2
(note the “!” in front of interface names … it means “not ”).
Keeping in mind that every firewall chain has implicit last rule with action=accept, it would be easier (safer, more restrictive … name it whatever you want) to change the above to
add chain=input action=accept dst-address=10.1.0.1 in-interface=bridge1
add chain=input action=accept dst-address=10.2.0.1 in-interface=bridge2
Any other necessary (accept) rules would go above the last (unconditional) drop rule.
