Isolate two networks
Hi, i am new, and already have a bunch of questions :slight_smile:
So here it is.
How do i isolate two network interfaces, so only one is “admin” interface and other just for the internet. Let’s say i assign ip to eth2 10.8.8.1 and set up dhcp.
Similary, i assign ip to eth3 10.8.7.1 and set up dhcp (so each dhcp with proper pool, network). I connect one computer to eth2 and one to eth3. Right now, both have access to internet, and to each other (router dynamically adds route), if i for example know their ip and perform iperf test .
Now i want, that eth3 is just for the internet.
So i created firewall rule:
chain=forward
in. interface=eth3
out. interface=!eth1_gateway (my wan)
action=drop
So far so good. I have access to internet from eth3. I can’t reach computers to 10.8.8.0 network, BUT i can access webfig (and i don’t want that, because on eth3 will be public internet), which is on 10.8.8.1 AND 10.8.7.1 (btw, why is webfig on every interface?).
So i created another rule (ip/firewall/filter)
chain=input
in. interface=eth3
action=drop
But this also prevent access to internet. I know that webfig can be “controlled” from /ip/services, but i also want to prevent all input traffic - to router, so i can be shure, no one can access not just webfig, but any other “input point”. Yeah, i know how to complicate things :slight_smile:
I have ROS 6.11 and RB2011UiAS-2HnD-IN.
Any help would be appreciated!
p.s.: I am sorry, if this sort of question was already addressed. I searched for similar topic but with no luck.
From Internet to directly inside the service of the Router is used the chain INPUT not the chain FORWARD…
Simply drop all new connection from ether1 on input chain.
On ip/services you can specify what ip address are able to access www (webfig) service.
Thank you for yor help, I somehow managed to solve this. The problem was, when I blocked all input traffic from ether3, it was also blocking DNS traffic.
So I just properly configured ip/services.
