My firewall/router has 3 LANs on 3 separate ports (ether2 = 10.10.10.0/24, ether3 = 172.16.20.0/24, and ether4 = 172.16.20.0/24) and the WAN on ether1. I am not using a bridge on any of the ports, yet I can ping/SSH every device from any LAN to any LAN. I would like to isolate the LAN on port ether4 so that devices on that LAN can’t communicate with each other, nor SSH/PING out to the other 2 LANS on ports ether2 and ether3. On the other hand, I would like be able to SSH/PING from the LANS on ports ether2 and ether3 to ether4 to manage devices on that LAN. Below is an export of my configuration.
What firewall rule do I need to add/change/reorder in order to make that happen?
Thank you!
# 2023-11-02 00:52:09 by RouterOS 7.10.2
# software id = #########
set [ find default-name=ether5 ] comment="10G SFP+ RJ45 WAN Port" \
disable-running-check=no name=ether1
set [ find default-name=ether1 ] comment="10G SFP+ DAC HOUSE LAN port" \
disable-running-check=no name=ether2
set [ find default-name=ether4 ] comment="Onboard 1G MGMT/DEV LAN port" \
disable-running-check=no name=ether3
set [ find default-name=ether2 ] comment="10G SFP+ SR PROD LAN" \
disable-running-check=no name=ether4
set [ find default-name=ether3 ] comment="10G SFP+ port" \
disable-running-check=no name=ether5
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
/disk
set slot1 slot=slot1 type=hardware
set slot2 slot=slot2 type=hardware
set slot3 slot=slot3 type=hardware
set slot4 slot=slot4 type=hardware
set slot5 slot=slot5 type=hardware
set slot6 slot=slot6 type=hardware
set slot7 slot=slot7 type=hardware
set usb1 type=hardware
add name=WAN
add name=LAN
add comment=HOUSE name=dhcp_pool_ether2 ranges=10.10.10.50-10.10.10.199
add comment=MGMT/DEV name=dhcp_pool_ether4 ranges=\
192.168.20.50-192.168.20.199
add comment=PROD name=dhcp_pool_ether3 ranges=172.16.100.50-172.16.100.199
add address-pool=dhcp_pool_ether2 comment="HOME LAN" interface=ether2 name=\
dhcp-ether2
add address-pool=dhcp_pool_ether4 comment="PROD LAN" interface=ether4 name=\
dhcp-ether4
add address-pool=dhcp_pool_ether3 comment="MGMT/DEV LAN" interface=ether3 \
name=dhcp-ether3
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
/interface wireguard peers
add allowed-address=10.10.20.3/32 interface=wireguard1 public-key=\
add address=10.10.10.1/24 comment="HOME LAN" interface=ether2 network=\
10.10.10.0
add address=10.10.20.1/24 comment="WIREGUARD VPN" disabled=yes interface=\
wireguard1 network=10.10.20.0
add address=192.168.20.1/24 comment="PROD LAN" interface=ether4 network=\
192.168.20.0
add address=172.16.100.1/24 comment="MGMT/DEV LAN" interface=ether3 network=\
172.16.100.0
/ip dhcp-server lease
add address=10.10.10.0/24 comment="HOUSE DHCP Range" dns-server=\
10.10.10.1,8.8.8.8 gateway=10.10.10.1 netmask=24
add address=172.16.100.0/24 comment="MGMT/DEV DHCP Range" dns-server=\
172.16.100.1,8.8.8.8 gateway=172.16.100.1 netmask=24
add address=192.168.20.0/24 comment="PROD DHCP Range" dns-server=\
192.168.20.1,8.8.8.8 gateway=192.168.20.1 netmask=24
set allow-remote-requests=yes servers=10.10.10.1,172.16.100.1,192.168.20.1
/ip firewall address-list
add address=10.10.10.2-10.10.10.254 comment="Allow Home LAN" list=\
allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=\
not_in_internet
add address=172.16.100.2-172.16.100.254 list=allowed_to_router
add address=192.168.20.2-192.168.20.254 list=allowed_to_router
add action=accept chain=input comment="default configuration" \
connection-state=established,related disabled=yes
add action=accept chain=input comment="ALLOW to router IPs from address list" \
src-address-list=allowed_to_router
add action=accept chain=input comment="Enable ICMP access" protocol=icmp
add action=accept chain=input comment="Wireguard VPN" disabled=yes dst-port=\
13231 log=yes log-prefix=WIREGUARD protocol=udp
add action=drop chain=input comment="Drop everything else, log=yes" log=yes
add action=fasttrack-connection chain=forward comment=\
"FastTrack for established, related" connection-state=established,related \
hw-offload=yes
add action=accept chain=forward comment="ACCEPT Established, Related" \
"DROP invalid connection and log them with prefix \"invalid\"" \
connection-state=invalid log=yes log-prefix=invalid
add action=drop chain=forward comment="DROP incoming packets that are not NAT`\
ted (DROP access to clients behind NAT from WAN)" connection-nat-state=\
!dstnat connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
"Drop incoming from internet which is not public IP" in-interface=ether1 \
log=yes log-prefix=!public src-address-list=not_in_internet
add action=masquerade chain=srcnat comment=Masquerade out-interface-list=WAN
add action=dst-nat chain=dstnat comment=\
"Forwarding Plex port 32450 to 10.10.10.16 port 32400" dst-port=32450 \
in-interface=pppoe-out1 log=yes protocol=tcp to-addresses=10.10.10.16 \
to-ports=32400
add action=dst-nat chain=dstnat comment="range01 TCP ports 11000-11999" \
dst-port=11000-11999 in-interface=pppoe-out1 port="" protocol=tcp \
to-addresses=192.168.20.101 to-ports=11000-11999
add action=dst-nat chain=dstnat comment="range01 UDP ports 11000-11999" \
dst-port=11000-11999 in-interface=pppoe-out1 protocol=udp to-addresses=\
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 nd
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=ca.pool.ntp.org
add address=time.nrc.ca
/system scheduler
add comment="Update Dynu DDNS" interval=5m name=ddns_sheduller on-event=\
"/system script run Dynu\r\
\n" policy=read,write,test start-time=startup
/system script
add dont-require-permissions=yes name=Dynu owner=###### policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
system script\r\
\nadd name=Dynu\r\
\npolicy=read,write,test\r\
\n:global ddnsuser \"######\"\r\
\n:global ddnspass \"################\"\r\
\n:global theinterface \"ether1\"\r\
\n:global ddnshost \"#################\"\r\
\n:global ipddns [:resolve \$ddnshost];\r\
\n:global ipfresh [ /ip address get [/ip address find interface=\$theinter\
face ] address ]\r\
\n:if ([ :typeof \$ipfresh ] = nil ) do={\r\
\n:log info (\"DynuDDNS: No IP address on \$theinterface .\")\r\
\n} else={\r\
\n:for i from=( [:len \$ipfresh] - 1) to=0 do={\r\
\n:if ( [:pick \$ipfresh \$i] = \"/\") do={\r\
\n:set ipfresh [:pick \$ipfresh 0 \$i];\r\
\n}\r\
\n}\r\
\n:if (\$ipddns != \$ipfresh) do={\r\
\n:log info (\"DynuDDNS: IP-Dynu = \$ipddns\")\r\
\n:log info (\"DynuDDNS: IP-Fresh = \$ipfresh\")\r\
\n:log info \"DynuDDNS: Update IP needed, Sending UPDATE...!\"\r\
\n:global str \"/nic/update\?hostname=\$ddnshost&myip=\$ipfresh\"\r\
\n/tool fetch address=api.dynu.com src-path=\$str mode=http user=\$ddnsuse\
r password=\$ddnspass dst-path=(\"/Dynu.\".\$ddnshost)\r\
\n:delay 1\r\
\n:global str [/file find name=\"Dynu.\$ddnshost\"];\r\
\n/file remove \$str\r\
\n:global ipddns \$ipfresh\r\
\n:log info \"DynuDDNS: IP updated to \$ipfresh!\"\r\
\n} else={\r\
\n:log info \"DynuDDNS: dont need changes\";\r\
\n} }"
/tool mac-server
/tool mac-server ping
set enabled=no
