Isolating Wireless Clients in Hotspot
Hi There,
I have a hotspot setup in the following configuration.
Wirless DHCP pool for wireless clients - 10.5.50.2-10.5.50.254
Lan interface on the hotspot is - 192.168.1.1
Adsl router is 192.168.1.254
I want to make sure that the wireless clients that connect to can not communicate with each other.
eg somone on 10.5.50.254 can not ping 10.5.50.253
I tried setting up the following rule but it did not work.
Src ip: 10.5.50.2-10.5.50.254
Dst IP: 10.5.50.2-10.5.50.254
Action Drop
Any ideas ???
Disable “default foward” in WinBox or set default forwarding=no in command line.
This worked up until a user logged in.
I found that I had to include the firewall rules as well to make it work
Can you show an example hot to set that up, we need to deploy a working hotspot realy fast, and we need to isolate co client to client communication + shared folders etc.
Regards
Pam Go into IP - Firewall - Add a Rule - General Tab
For both SRC Address and DST Address enter the following
10.5.50.2-10.5.50-254
On the action tab select DROP
Thats it !
