I have a question, we are talking about a small internet service provider that has about 800-1200 users and one or two cloud core routers.
The question is, how to manage clients, IP addressing, and internet speed, with as little processor load as possible?
There is such an idea that we use different subnets and VLANs, but limited resources, for example
If you do not give the full story about your company & services, how could it be possible to even provide tips & tricks on this ?
For sure PPPoE will be the most “cpu intensive” I think but it has advantages on scalability & operational level.
…and 800-1200 users is not much, so even using PPPoE could be done on a single box.
How are you clients connected ? Cable ? Fiber ? Are you a WISP-type of provider ?
Do you manage/own the last mile of cable to your clients ? Or do you “wholesale” from another local carrier or something?
You provide sooooo little information so don’t expect too much in return.
I don’t really understand why it’s important to know how services are provided, after all, the point is to manage the client from the central router.
So, we provide services both via wisp and via gpon. Currently, clients have their own ip subnet and their own vlan. But I want to ask if there is some more optimal solution, how others behave. We provide clients with 50-100mbs of speed via wisp, and 100-500mbs of speed via gpon.
If you ask for free advices how to improve your payable services then IMHO you should unhide at least a little details and do not treat helpers as enemies. Otherwise you should consider hiring professional advisor that you could be snippy to.
Well, I’m not really a hater, I’m asking a serious simple question that I haven’t received an answer from either me or any of the previous users. Also, I see you recommend consultants, so I’ve really called more than one and none of them helped. But as I mentioned, I solved this problem myself
Oh, when you need help, maybe I can help. Because I only see one user currently offering a pppoe solution, I only hear more about configuration requests
