ISP PPPoE Server - Change Dynamic Route Distance for FailOver
Hi everyone, I have a Mikrotik PPPoE server that handles about 1000 connections (we are an ISP)
To some of our customers we provide a backup line with different technology from the main one, for example the main one in FTTH, backup via FWA / Wireless.
Both lines authenticate to our PPPoE Server
In the routing table a DAC route with weight 0 is created with dst-address = IP Client and on the interface the dynamically created PPPoE interface.
The problem is that both sessions are on distance = 0. I would like the main one to be distance = 0 and the secondary one with a greater distance, in this way the backup line is used only in case of failure of the primary.
With both distances set to 0 the traffic passes from the line that authenticated last, so I would run the risk of sending the traffic to the customer on the backup line
We use the same username / password on both sessions so that we can also backup any Static IPs / Network Subnets / 29
The PPPoE Server for customer auth relies on our Radius Server
Some advice?
Up!
Solved
If possible please tell how it was solved since it might be good for others to know with similar problems. Thanks in advance!
Let’s suppose we have a login like:
test@test.com, this login is configured on an FTTC access and test1@test.com on an FWA access. Both logins must deliver the same IP / Subnet address to the customer. The FTTC login is the master, the FWA login is the backup. Both logins are configured on the same customer CPE
At the Radius level:
test@test.com
Framed-IP-Address> 10.219.100.1 (example)
Framed-Route> 1.2.3.4/32 10.219.100.1 1
1.2.3.4/32 is the subnet to route
10.219.100.1 is the Framed-IP-Address
1 is the distance that will be learned in the PPPoE server
test1@test.com
Framed-IP-Address> 10.219.100.2 (example)
Framed-Route> 1.2.3.4/32 10.219.100.2 2
10.219.100.2 is the Framed-IP-Address
2 is the distance that will be learned in the PPPoE server
In this way the PPPoe Server will have distance 1 on the FTTC access and distance 2 on the FWA access. If the FTTC line has problems, the failover is instantaneous.
