ISP switched to Mikrotik 1009
I am a new ISP. We have started with Mikrotik CCR 1009.
We were using small Mikrotik routers before. We just became ISP ourself because no ISP wanted to serve our small hilly town.
We are using Mikrotik CCR 1009.
Here is the setup.
  1. Fibre SFP1 … WAN 1
  2. Ether 5… WAN 2 (setup as failover)
  3. Ether 2 … PPPoE using /24 Public IP Pool. serving 80 clients.
Above configuration is fine and working perfectly.
Now I want to do following. Please if any expert on RouterOS can Help me out
  1. i have second pool /24 of Public IP
  2. Some clients want 2,4,8 (/30 /29 etc) static IP. (if any client uses one static IP i can give easily in PPPOe)
  3. How can i use second pool and use this. (is vlan good)
Presumably the second /24 is routed to you, and you drop or reject any unused addresses to prevent routing loops.
With PPPoE there is no need for VLANs to provide multiple addresses - if using RADIUS include a Framed-Route attribute to forward whatever sized subnet to the client.
I must go away and return later, but the second /24 where are coming from?
you have one /24 with two address used 1 from ISP 1 from your WAN
or you have one /24 throug two separated IP for “PTP” from ISP and you?
on this last case, simply add new IP pool to already existent pppoe-server pool
add both full /24 pool to blackhole on route with disctance=2 for skip loop and scan,
when someone connect/use public ip on pppoe, it add automatically route with distance=1 to CPE
The failover route all /24 or you masquerade?
Thank you very much for a quick reply! i am a bit of a noob. excuse me if i sound stupid at times.
  1. Yes i have /22 Block (all routed) of IP from IRINN (Indian version of Apnic). I am using only one block (/24) I plan to use another block (/24) for people who wants more than (1 static IPs )
  2. I am using DMA. It has only option to give one static IP. how to include this framed -route attb.
In the ‘Custom RADIUS attributes’ box. You still have to specify the primary address by selecting ‘IP address mode CPE: Static IP’ and entering an address.
There are two methods, you can either use ‘Framed-IP-Netmask’ to specify a netmask which will be applied to the primary address
e.g. for a /30 it would be Framed-IP-Netmask=255.255.255.252
or you can use ‘Framed-Route’ to specify a route which may overlap with the primary address or not as you desire
e.g. Framed-Route=“192.168.100.17/30 0.0.0.0 1”
In both cases under IP > Routes the primary address appears as ‘DAC’, and the routed subnet as ‘DAS’.
Create a subnet of /29 or /28 and provide it to your customers,
Your upstream provider should help you on this, In our country there are too many providers with very poor service..
