【Issue】I can not use Java Applet of iLO4 in CRS.
I am using a CRS125-24G-1S, but it afflicts the head to some problem.
It’s a problem that occurs when you have connected a iLO4 of hp ML110 G7 and PC, but it is a problem if you try to use the Java Applet version when using the Virtual KVM, that does not come up.
This problem has been confirmed that you come to start properly when it is replaced by a different switch.
How does this wonder should I modify the settings of CRS?
Server PC and belongs to a group of port SFP1.
I am glad I and able to help.
Best regards.
[admin@MikroTik] /interface ethernet> export
# dec/09/2013 14:08:51 by RouterOS 6.8rc1
# software id = 1P0B-5LGC
set [ find default-name=ether21 ] l2mtu=4064 mtu=4000
set [ find default-name=ether22 ] l2mtu=4064 master-port=ether21 mtu=4000
set [ find default-name=ether23 ] l2mtu=4064 master-port=ether21 mtu=4000
set [ find default-name=ether24 ] l2mtu=4064 master-port=ether21 mtu=4000
set [ find default-name=sfp1 ] l2mtu=1598
set [ find default-name=ether1 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether2 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether3 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether4 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether5 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether6 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether7 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether8 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether9 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether10 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether11 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether12 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether13 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether14 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether15 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether16 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether17 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether18 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether19 ] l2mtu=1598 master-port=sfp1
set [ find default-name=ether20 ] l2mtu=1598 master-port=sfp1
/interface ethernet switch
set bridge-type=service-vlan-bridge bypass-l2-security-check-filter-for="" \
    bypass-vlan-ingress-filter-for="" \
    drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="" \
    drop-if-no-vlan-assignment-on-ports="" egress-mirror-ratio=1/1 \
    egress-mirror0-enable=yes egress-mirror0-format=modified \
    egress-mirror0-port=switch1-cpu egress-mirror0-port=switch1-cpu \
    egress-mirror1-enable=yes egress-mirror1-format=modified \
    egress-sampling-ratio=1/1 fdb-uses=mirror0 forward-invalid-vlan=yes \
    ingress-mirror-ratio=1/1 ingress-mirror0-enable=yes \
    ingress-mirror0-format=modified ingress-mirror0-port=switch1-cpu \
    ingress-mirror1-enable=yes ingress-mirror1-format=modified \
    ingress-mirror1-port=switch1-cpu invalid-vlan-lookup-mode=ivl \
    ipv4-multicast-lookup-mode=dst-mac-and-vid-always mac-level-isolation=no \
    mirror-egress-if-ingress-mirrored=no mirror-tx-on-mirror-port=no \
    mirrored-packet-drop-precedence=green mirrored-packet-qos-priority=0 \
    override-existing-when-ufdb-full=no unicast-fdb-timeout=5m \
    use-cvid-in-one2one-vlan-lookup=yes use-svid-in-one2one-vlan-lookup=no \
    vlan-level-isolation=no vlan-uses=mirror0
