Hi all,
could you please so kind tio help /assist me ?
I have the setting :
Draytek Modem ->MT RB 2011iL → Fritzbox Router (as client only for telephony).
It works everything..but sometimes if i get an in call or fax the complete pppoe is disconnecting.. and thats the bigger issue the telephony not works anymore.. Internet works
In the log of the FB i cant see an incoming call .. so i am not sure if the MT or a missconfig is the problem. But why it works a while without issue?
So what can i do ( look , check ) or what do you need to assist / help me??
Thanks a lot
Regards
Cyb
p.s. i changed already the Modem.. so i dont think its the problem.
