Hello all,
I have an issue with ARP which I’m not able to fix, so I hope someone here will understand what’s happening.
I have a Mikrotik router running RouterOS v6.48.6 which provides DHCP service for my LAN and has one interface (ether1) connected to the ISP’s router. All the others, including two wifi, interfaces are members of a bridge.
Connected to ether5 I have an unmanaged switch and, attached to it, another AP.
Clients (wired and wifi) connected to that AP often cannot reach internet because they cannot resolve the default gateway’s ARP address. This address in on the bridge interface which has of course, arp activated.
With packet sniffer on the router I can see the ARP requests for it, but it seems I cannot see the replies.
Putting a static entry on client machines solves the issue. The issue happens with PC and phones, m$ and linux, with static and dhcp assigned IPs, wired or wifi, and I’ve changed 3 different APs. I suspect, but it is harder to be 100%, it happens also on a TV box which is directly wired into the switch (I cannot set static ARP entries into that).
jun/10/2023 16:03:30 by RouterOS 6.48.6
add admin-mac=02:00:00:00:01:01 auto-mac=no comment=Bridge fast-forward=no name=bridge
set [ find default-name=ether1 ] comment=“Link verso Internet”
set [ find default-name=ether2 ] comment=“Link verso SmartTV”
set [ find default-name=ether5 ] comment=“Link verso la cucina”
/interface 6to4
add !keepalive local-address=192.168.1.1 name=6rd remote-address=81.208.50.214
/interface vlan
add interface=bridge name=guest vlan-id=2
add name=WAN
add name=LAN
add authentication-types=wpa2-psk eap-methods=“” management-protection=allowed mode=dynamic-keys name=REDACTED supplicant-identity=“” wpa2-pre-shared-key=REDACTED
add authentication-types=wpa2-psk eap-methods=“” management-protection=allowed mode=dynamic-keys name=“REDACTED " supplicant-identity=”" wpa2-pre-shared-key=REDACTED
add authentication-types=wpa2-psk eap-methods=“” group-ciphers=tkip,aes-ccm management-protection=allowed mode=dynamic-keys name=REDACTED supplicant-identity=“” unicast-ciphers=tkip,aes-ccm
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-g/n country=italy disabled=no distance=indoors installation=indoor mode=ap-bridge security-profile=REDACTED ssid=
REDACTED station-roaming=enabled wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
set [ find default-name=wlan2 ] adaptive-noise-immunity=ap-and-client-mode band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=italy disabled=no frequency=5640 installation=indoor mode=ap-bridge
security-profile=REDACTED ssid=REDACTED station-roaming=enabled wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add mac-address=RE:DA:CT:ED:F7:43 master-interface=wlan1 name=wlan3 security-profile=LREDACTED ssid=REDACTED vlan-id=2 wds-default-bridge=bridge wps-mode=disabled
add mac-address=RE:DA:CT:ED:F7:44 master-interface=wlan2 name=wlan4 security-profile=REDACTED ssid=REDACTED vlan-id=2 wds-default-bridge=bridge wps-mode=disabled
add keepalive-frames=disabled mac-address=RE:DA:CT:ED:F7:41 master-interface=wlan1 mode=station multicast-buffering=disabled name=REDACTED security-profile=REDACTED ssid=“REDACTED”
station-roaming=enabled wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
add mac-address=RE:DA:CT:ED:F7:42 master-interface=wlan1 mode=station multicast-buffering=disabled name=hotspot-work security-profile=“REDACTED” ssid=REDACTED station-roaming=enabled wds-cost-range=0
add name=std-pool ranges=172.30.2.100-172.30.2.199
add name=docker-macvlan ranges=172.30.2.32/27
add name=guest-pool ranges=192.168.0.1-192.168.0.9
add address-pool=std-pool disabled=no interface=bridge name=dhcp-main
add address-pool=guest-pool disabled=no name=server1
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
add bridge=bridge comment=defconf hw=no interface=ether2
add bridge=bridge comment=defconf interface=wlan2
add interface=wlan3 pvid=2
add interface=wlan4 pvid=2
/interface bridge settings
set allow-fast-path=no use-ip-firewall-for-pppoe=yes use-ip-firewall-for-vlan=yes
set enabled=yes icmp-timeout=30s loose-tcp-tracking=no tcp-close-timeout=30s tcp-close-wait-timeout=1m tcp-established-timeout=5d tcp-fin-wait-timeout=2m tcp-last-ack-timeout=30s tcp-syn-received-timeout=2m
tcp-syn-sent-timeout=1m tcp-time-wait-timeout=2m tcp-unacked-timeout=1d5m udp-stream-timeout=30s
add interface=bridge list=LAN
add interface=ether1 list=WAN
add interface=6rd list=WAN
/interface wireless connect-list
add disabled=yes interface=REDACTED security-profile=REDACTED ssid=“REDACTED”
add address=172.30.2.250/24 interface=bridge network=172.30.2.0
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
add address=192.168.0.254/24 network=192.168.0.0
add address=172.30.2.99/24 interface=bridge network=172.30.2.0
/ip cloud
set update-time=no
/ip dhcp-client
add default-route-distance=3 disabled=no interface=REDACTED use-peer-dns=no use-peer-ntp=no
add default-route-distance=2 !dhcp-options disabled=no interface=REDACTED use-peer-dns=no use-peer-ntp=no
/ip dhcp-server config
set store-leases-disk=never
add address=172.30.2.0/24 dns-server=172.30.2.250 gateway=172.30.2.250 netmask=24 ntp-server=172.30.2.200
add address=192.168.0.0/24 dns-server=192.168.0.254 gateway=192.168.0.254
set allow-remote-requests=yes cache-max-ttl=52w1d10m servers=2001:4860:4860::8888,2001:4860:4860::8844,8.8.8.8,8.8.4.4/ip ipsec policy
set 0 disabled=yes
/ip proxy
set anonymous=yes
/ip proxy access
add src-address=0.0.0.0
add check-gateway=ping distance=10 gateway=192.168.1.254
add distance=1 dst-address=10.0.0.0/8 type=blackhole
add distance=1 dst-address=100.64.0.0/16 gateway=172.30.2.200
add distance=1 dst-address=172.16.0.0/12 type=blackhole
add distance=1 dst-address=172.31.0.0/16 gateway=172.30.2.200
add distance=1 dst-address=192.168.0.0/16 type=blackhole
/ip socks
set connection-idle-timeout=1h30m enabled=yes
/ip socks access
add dst-port=80 src-address=172.30.2.0/24
add dst-port=443 src-address=172.30.2.0/24
/ipv6 address
add address=REDACTED advertise=no interface=6rd
add address=REDACTED interface=bridge
add address=REDACTED advertise=no comment=Mio disabled=yes interface=bridge/ipv6 nd
set [ find default=yes ] advertise-dns=no disabled=yes ra-interval=1m-2m ra-lifetime=3m
add advertise-dns=no interface=bridge ra-interval=20s-1m ra-lifetime=2m
add disabled=yes managed-address-configuration=yes other-configuration=yes ra-interval=20s-1m ra-lifetime=2m
/ipv6 nd prefix
add autonomous=no preferred-lifetime=5m valid-lifetime=10m
/ipv6 nd prefix default
set preferred-lifetime=5m valid-lifetime=10m
/ipv6 route
add distance=1 dst-address=2000::/3 gateway=6rd
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=GW-250
/system ntp client
set enabled=yes primary-ntp=193.204.114.232 secondary-ntp=193.204.114.233
/system package update
set channel=long-term
/tool graphing interface
add interface=6rd
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-operator-between-entries=and filter-stream=yes streaming-enabled=yes streaming-server=172.30.2.200
I’ve redacted SSID and passwords. I’ve also altered the MAC Addresses for wifi interfaces changing only the first 12 bytes, leaving the remaining 4 intact. The bridge mac address was set to static just to help in the troubleshooting. Previously was automatically assigned and the issue was present. I’ve now set it to a legit, unique, static and easy to remember address (02:00:00:00:01:01).
I’ve also cut out both IPv4 and IPv6 firewall and address lists: since the issue is on ARP I think those aren’t relevant.
Please let me understand this issue: I really have no idea. Any help appreciated. Also, if needed, I can perform some tests.
Thanks,
Radel
