Issue with ip/cloud.
Hello everyone,
is there an issue with DDNS at the moment ?
I have my routers with DDNS and status “updating”, but apparently the service is down or the router is not able to reach it.
Does anybody else have issues with the service ?
I have the same Issue
I also encountered the same case, maybe there is a solution with this problem?
Same here
Still … updating …
Perhaps will solve as soon as possible
I have also reported this to MikroTik support, so they can check their server status.
same here.
Happened about 1,5 hrs ago. carrier modem reloaded and got new IP, and since then DDNS is not updating.
Already registered devices are working fine.
Looks like there is an issue with Mikrotik’s domain again.
I have just got reply from MikroTik support; the issue is now resolved.
I checked my routers and now the DDNS service is working again.
Seems to “happen” every so often.
Wouldn’t it be nice if it would show right at the top of this forum.
"Mikrotik Cloud Status: ______ "
The issue persist in all my devices. The service is very unstable a days ago.
It fails again… since January 3rd it is not backing up to the cloud correctly.
/system backup cloud
upload-file action=create-and-upload password=myPasswSecure replace=[find name]
status: Server error: backend error
Mikrotik support: any serious problems?
BR.
