Issue with NAT and internal Subnets
I have several internal subnets with WAN Access and the following NAT-Rule:
add action=masquerade chain=srcnat comment="masquerade LAN->WAN" out-interface-list=WAN
Internet works for all VLAN Subnets, but I have an issue with Multicast Routing within my subnets. If I disable the NAT Rule (only for test purposes), everything works! So I think, I have to exclude all internal Subnes from SrcNat. But I am struggling with the configuration. All attempts failed! I have a dynamic WAN IP from ISP.
Can someone help me to change my NAT rule?
Thanks,
Christian
Does interface list “WAN” contains only your ISPs interfaces?
yes, it is ether1 (WAN)
Christian
What ROS and firmware version do you use?
I use 6.42.6 and FW3.41 on RB3011
Christian
Given the issue as you describe it, give this a try …
add action=masquerade chain=srcnat comment="masquerade LAN->WAN" out-interface-list=WAN src-address-type=!multicast
thanks for the modification of the NAT-Rule, but it is not working!
Let me try to explain the whole story. Maybe some has an idea:
I have Sonos palyers on vlan30 and controller on vlan10 and vlan60 (interface-list “Sonos Control”). PIM is working and I implemented the following FW-rules:
add action=accept chain=forward comment="SONOS: forward Multicast traffic" \
    dst-address=239.255.255.250
    "SONOS: forward  Controller events to Players" dst-port=1400,4444,4070 \
    in-interface-list="Sonos Control" out-interface=vlan30 protocol=tcp
    "SONOS: Forward Contoller events  from Players" dst-port=\
    3400,3401,3500,4070 in-interface=vlan30 out-interface-list=\
    "Sonos Control" protocol=tcp
    "SONOS. Forward UPnP Device Discovery events from Players" dst-port=\
    1900,1901,5353,6969 in-interface=vlan30 out-interface-list=\
    "Sonos Control" protocol=udp
Sonos works across different subnets as long as player and controller were initially setup in the same subnet.
This means:
My issue is only present for initial player/controller setup, although all relevant ports are free (checked with Sonos support). I cannot connect new players/controllers to the Sonos system if player and controller are in different subnets.
Workaround:
bring new player/controller to vlan30 (Sonos SubNet), temporary!
But:
If I disable the NAT Rule (see above) I can connect new devices accross the subnets and I do not understand why this is the case!
This must have something to do with the NAT-Rule
Christian
