Issue with RADIUS + Hotspot: Randomized Phone MAC Addresses Causing Per-User Device Limit Problems
Hello everyone,
I am facing a problem with my MikroTik Hotspot + RADIUS setup, and I would appreciate some guidance from the community.
I am using a RADIUS server (daloRADIUS) for authentication. In my configuration, each user is allowed to use only one device (per-user 1 device policy). However, modern smartphones (both Android and iPhone) use randomised/private MAC addresses, which rotate frequently.
This causes the following issues:
  1. Every time the phone changes its MAC address, MikroTik treats it as a new device.
  2. The Hotspot cookie stores the old MAC address, so the router becomes confused.
  3. The RADIUS server sees a different MAC each time, and the user exceeds the “1 device only” limit.
  4. Users get disconnected or cannot log in because the system thinks they are using multiple devices.
I want to know if there is any recommended MikroTik-side solution for this modern behaviour of rotating MAC addresses. My goals are:
  • Keep the “one user → one device” policy.
  • Avoid forcing users to manually disable private MAC (not a scalable solution).
  • Prevent the router from creating multiple device entries for the same user.
  • Allow a consistent identity for authentication even if the MAC changes.
My environment:
  • RouterOS version: 6.49.18 (long-term)
  • Hotspot authentication with RADIUS
  • daloRADIUS backend
  • Per-user device limit enabled
  • Mostly smartphones (Android/iPhone)
Questions:
  1. Is there any MikroTik feature to handle randomised MAC addresses more gracefully?
  2. Can Hotspot or RADIUS bind the user session to something more stable than the MAC address?
  3. Is there any best practice for Hotspot environments with rotating MAC devices?
Any guidance or recommended configuration would be highly appreciated.
Thank you.
