Hi guys,
I’m new with Mikrotik Routerboard. I’m setting up a simple network.
I have a WAN interface (Port 1) with IP 10.185.145.253. The next hop, which is a VSAT modem, is configured for IP 10.185.145.254.
The LAN interface (Port 2) has IP 10.185.145.17, connecting to a PC/Server with static IP 10.185.145.19. All of them are under subnet 10.185.144.0/20.
After connecting all equipment, I’m unable to ping 10.185.145.254 from the PC/Server. However, after I ping the WAN interface 10.185.145.253 from the PC/Server, I can already ping 10.185.145.254 successfully. I’m not sure what’s causing the idling on the interface.
This becomes a problem when the router reboots due to power outage, etc. They need to ping the WAN interface first, to allow the communication to become active.
Any reason? Is it a firmware issue? This is v5.8.
