Issue with RB760 and L2TP causing router to be rebooted
Hi there,
We have an issue with a RB760iGS running different ROS versions, in particular we have tried 6.42.11 and 6.43.8 when running a L2TP dial in VPN server. A dial in user will connect and then it will cause the router to be rebooted. We have applied the configuration to another device with the same results. We have also reconfigured another device with basic requirements and can confirm same behaviour.
I have raised this directly with Mikrotik but was wondering if anyone else has experienced this issue.
Rob
Updated to this: I have enabled PPTP server as a test and i can confirm that i do not have the same issue, everything works as it should.
