Hi everyone, I have a router HAP Ax3 with 7.15.2 and CAP RBcAPGi-5acD2nD with 7.15.2 too. I have to use package “wifi qcom” to work CAP with HAP ax3.
I have a CAPMan enabled and configured. The problem is with roaming, in this moment my laptop is connected to CAP instead of the Router HAP ax3, when it is more near to router than to the CAP. If I stop laptop’s wifi and start, in this case, laptop connect to Router instead to CAP.
Can something be configured to make roaming work better?
My wifi config:
/interface wifi configuration
add channel.band=5ghz-ac country=Spain datapath.bridge=bridge disabled=no
mode=ap name=cfg5GHZ security.authentication-types=wpa2-psk,wpa3-psk
ssid=JUJUMAESIN-PLUS
add channel.band=2ghz-n country=Spain datapath.bridge=bridge disabled=no
mode=ap name=cfg2GHZ security.authentication-types=wpa2-psk,wpa3-psk
ssid=JUJUMAESIN
/interface wifi
set [ find default-name=wifi2 ] configuration=cfg2GHZ configuration.mode=ap
disabled=no name=wifi2GHZ
set [ find default-name=wifi1 ] configuration=cfg5GHZ configuration.mode=ap
disabled=no name=wifi5GHZ
/interface wifi capsman
set enabled=yes interfaces=bridge package-path=“” require-peer-certificate=no
upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=cfg2GHZ
supported-bands=2ghz-n
add action=create-dynamic-enabled disabled=no master-configuration=cfg5GHZ
supported-bands=5ghz-ac
