Issue with script and scheduler
So, I have a dynamic IP address assigned, and I have a script that, when run from the terminal, works perfectly and does what it is supposed to. When I run the script from the Script window in Winbox, it does what it should. When I create a schedule to run the script, it doesn’t work, and I receive the error executing the script from scheduler failed, please check manually
If anyone has any insights, it would be appreciated.
Scheduler has policies [read, write], On Event: scriptName, I have tried placing the script code in the On Event and get the same results.
Script has policies [read, write] code is below
:global getPublicIP do={
  # tag for temporary configurations
  :local tag "get-public-ip-via-$interface"
  # service that provides public ip address in http response
  :local lookupProtocol "https"
  :local lookupHostname "api.ipify.org"
  # add temporary address list for lookup service
  /ip firewall address-list add list=$tag address=$lookupHostname comment=$tag timeout=15s
  :delay 3;
  # configure temporary route to lookup service via a specific interface
  :foreach p in=[/ip firewall address-list find comment=$lookupHostname dynamic=yes] do={
    :local addr [/ip firewall address-list get $p address];
    /ip route add gateway=$gateway dst-address=$addr comment=$tag
  # fetch http response from lookup service
  :local result [/tool fetch url="$lookupProtocol://$lookupHostname" as-value output=user]
  # remove temporary address list
  /ip firewall address-list remove [find where comment=$tag]
  # remove temporary gateway route
  /ip route remove [find where comment=$tag]
  # return ip from lookup service response data
  :return ($result->"data")
:global i 0;
:global f 0;
:global listVar "";
:put ("Fetching Current IP ...");
:log info message=("Fetching Current IP ...");
:global currentIP [$getPublicIP interface="ether1-gateway" gateway="192.168.1.1"];
:put ("Current IP: $currentIP");
:log info message=("Current IP: $currentIP");
# find firewall rules with our comment in it, and put the number of rule in a list
:put ("Locating desired firewall rules...");
:log info message=("Locating desired firewall rules...");
:foreach c in=[/ip firewall nat find] do={
   :if ([:find [/ip firewall nat get $c comment] "CODE"]=0) do={
      :set $f ($f + 1)
      :if ([/ip firewall nat get $c dst-address]!=$currentIP) do={
         :put ("Updating firewall rule #$i");
         :log info ("Updating firewall rule #$i");
         /ip firewall nat set $c dst-address=$currentIP;
   :set $i ($i + 1);
:if ($f=0) do={
   :put ("No firewall rules to update");
   :log info ("No firewall rules to update");
:put ("Complete.");
:log info message=("Complete.");
You need the ftp policy enabled to be able to use /tool fetch in your scripts (read+write are not enough).
The script runs fine without the FTP policy when I run it from the script window itself and the terminal.
However, adding the FTP policy to the script and the Scheduler did not change the results. :frowning:
Found a solution. I played around with the policies and it looks like the only policies needed are [read, write, policy, test]
It now works running from the Script window, Terminal, and via Scheduler.
Also, for posterity this is v7.16.1 on hEX (mmips)
