Thanks for beeing so polite, teaching me how to use this forum correctly. I ll try to take your advice seriously using quotes and code snipplets.
First of all, wow, this setting immediately brought up the tunnel.
If I try to ping 100.70.2.18 it leads to a timeout.
# apr/12/2020 15:38:42 by RouterOS 6.45.8
# software id = AUPH-Q0VU
# model = RB4011iGS+5HacQ2HnD
# serial number = XXXX
add admin-mac=C4:AD:34:5F:46:4D auto-mac=no comment="Interne Bridge" name=bridge-int
set [ find default-name=ether1 ] comment="VDSL uplink Port"
set [ find default-name=ether2 ] comment="Unitymendia uplink Port"
/interface wireless
# managed by CAPsMAN
# channel: 5260/20-Ceee/ac/DP(17dBm)+5210/80/P(20dBm), SSID: SSID, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=germany distance=indoors frequency=auto installation=indoor mode=ap-bridge secondary-channel=\
auto ssid=MikroTik-5F4657 wireless-protocol=802.11
# channel: 2452/20-Ce/gn(17dBm), SSID: SSID, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=germany distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik-BE98CD \
/interface pppoe-client
add disabled=no interface=ether1 keepalive-timeout=5 name=TCom_pppoe password=XXX user=XXX0001@t-online.de
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=SSID passphrase=XXX
/caps-man configuration
add country=germany mode=ap name=SSID security=SSID ssid=SSID
/caps-man interface
add configuration=SSID datapath.bridge=bridge-int disabled=no l2mtu=1600 mac-address=C4:AD:34:12:B3:EE master-interface=none name=cap1 radio-mac=C4:AD:34:12:B3:EE \
radio-name=C4AD3412B3EE
add configuration=SSID datapath.bridge=bridge-int disabled=no l2mtu=1600 mac-address=C4:AD:34:12:B3:EF master-interface=none name=cap2 radio-mac=C4:AD:34:12:B3:EF \
radio-name=C4AD3412B3EF
add configuration=SSID datapath.bridge=bridge-int disabled=no l2mtu=1600 mac-address=C4:AD:34:5F:46:57 master-interface=none name=cap3 radio-mac=C4:AD:34:5F:46:57 \
radio-name=C4AD345F4657
add configuration=SSID datapath.bridge=bridge-int disabled=no l2mtu=1600 mac-address=74:4D:28:BE:98:CD master-interface=none name=cap4 radio-mac=74:4D:28:BE:98:CD \
radio-name=744D28BE98CD
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip ipsec mode-config
set [ find default=yes ] connection-mark=no-mark
/ip ipsec peer
add address=89.31.7.243/32 exchange-mode=ike2 local-address=192.168.42.1 name=swyx port=500
/ip ipsec policy group
set [ find default=yes ] name=1
/ip ipsec profile
set [ find default=yes ] dh-group=modp1536 dpd-interval=1m enc-algorithm=aes-256 hash-algorithm=sha256 lifetime=1h nat-traversal=no
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc lifetime=1h pfs-group=modp1536
add name=dhcp ranges=192.168.42.10-192.168.42.254
add address-pool=dhcp disabled=no interface=bridge-int lease-time=2w name="Intern_DHCPD "
/ppp profile
set *0 on-up=":delay 180s\r\
\n/system script run ddserver"
/caps-man manager
set enabled=yes
add bridge=bridge-int comment=defconf interface=ether5
add bridge=bridge-int comment=defconf interface=ether6
add bridge=bridge-int comment=defconf interface=ether7
add bridge=bridge-int comment=defconf interface=ether8
add bridge=bridge-int comment=defconf interface=ether9
add bridge=bridge-int comment=defconf interface=ether10
add bridge=bridge-int comment=defconf interface=sfp-sfpplus1
add bridge=bridge-int interface=ether3
add bridge=bridge-int interface=ether4
add interface=bridge-int list=LAN
add interface=ether2 list=WAN
add interface=TCom_pppoe list=WAN
/interface wireless cap
set caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1,wlan2
add address=130.180.X.X/29 interface=ether2 network=130.180.X.X
add address=192.168.42.1/24 interface=bridge-int network=192.168.42.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge-int
/ip dhcp-server lease
add address=192.168.42.42 mac-address=00:01:2E:48:CB:30 server="Intern_DHCPD "
add address=192.168.42.0/24 comment=LAN gateway=192.168.42.1 netmask=24
set allow-remote-requests=yes servers=149.112.112.112,2620:fe::fe,9.9.9.9,2620:fe::9
/ip dns static
add address=192.168.42.1 name=router.lan
add address=100.70.2.18 name=swyx.local
add action=drop chain=input dst-port=53 in-interface=TCom_pppoe protocol=udp
add action=drop chain=input dst-port=53 in-interface=ether2 protocol=udp
add action=accept chain=output dst-address=127.0.0.1 port=5246,5247 protocol=udp src-address=127.0.0.1
add action=accept chain=input dst-address=127.0.0.1 port=5246,5247 protocol=udp src-address=127.0.0.1
add action=passthrough chain=input dst-port=500,4500 in-interface=TCom_pppoe log=yes protocol=udp
add action=accept chain=input in-interface=TCom_pppoe protocol=ipsec-esp
add action=accept chain=input in-interface=ether2 protocol=ipsec-esp
add action=accept chain=input in-interface=TCom_pppoe protocol=ipsec-ah
add action=passthrough chain=input dst-port=500,4500 in-interface=ether2 protocol=udp
add action=fasttrack-connection chain=forward comment=FastTrack connection-mark=!ipsec connection-state=established,related
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-connection chain=forward comment=" Mark IPsec" disabled=yes ipsec-policy=out,ipsec new-connection-mark=ipsec passthrough=yes
add action=mark-connection chain=forward comment=" Mark IPsec" disabled=yes ipsec-policy=in,ipsec new-connection-mark=ipsec passthrough=yes
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=TCom_pppoe
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=ether2
/ip ipsec identity
add generate-policy=port-override my-id=user-fqdn:user@address.de notrack-chain=output peer=swyx remote-id=user-fqdn:vpn@swyxon.com secret=\
/ip ipsec policy
add dst-address=100.70.2.18/32 peer=swyx sa-dst-address=89.31.7.243 sa-src-address=192.168.42.1 src-address=192.168.42.0/24 tunnel=yes
add disabled=yes dst-address=192.168.42.0/24 peer=swyx sa-dst-address=89.31.7.243 sa-src-address=192.168.42.1 src-address=100.70.2.18/32 tunnel=yes
/ip ipsec settings
set accounting=no
add check-gateway=ping distance=1 gateway=130.180.X.X
add check-gateway=ping distance=2 gateway=TCom_pppoe
add check-gateway=ping distance=1 dst-address=79.133.X.X/32 gateway=TCom_pppoe
add check-gateway=ping comment=swyxon.webconnect distance=1 dst-address=89.31.7.227/32 gateway=TCom_pppoe
add check-gateway=ping comment=swyxon.webconnect distance=2 dst-address=89.31.7.227/32 gateway=ether2
add check-gateway=ping comment="swyx VPN Endpunkt" distance=1 dst-address=89.31.7.243/32 gateway=TCom_pppoe
add check-gateway=ping comment="swyx VPN Endpunkt" distance=2 dst-address=89.31.7.243/32 gateway=ether2
/ipv6 address
add from-pool=TComIPv6 interface=bridge-int
/ipv6 dhcp-client
add add-default-route=yes interface=TCom_pppoe pool-name=TComIPv6 request=prefix use-peer-dns=no
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
add action=drop chain=input comment="incoming dns block" dst-port=53 in-interface=TCom_pppoe protocol=udp
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
/system identity
set name=XXXr_router
/system logging
add prefix="IPSEC: " topics=ipsec,!packet
add prefix=FIREWALL: topics=firewall
/system package update
set channel=long-term
/tool mac-server
/tool mac-server mac-winbox
/tool sniffer
set filter-interface=TCom_pppoe only-headers=yes
The output of the active-peers after the tunnel got enabled.
/ip ipsec active-peers> print
Flags: R - responder, N - natt-peer
# ID STATE UPTIME PH2-TOTAL REMOTE-ADDRESS DYNAMIC-ADDRESS
0 vpn@swyxon.com established 4m55s 1 89.31.7.243
Logfile
16:05:44 system,info ipsec policy changed by admin
16:05:47 ipsec IPSEC: : ph2 possible after ph1 creation
16:05:47 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:05:47 ipsec IPSEC: : init child continue
16:05:47 ipsec IPSEC: : offering proto: 3
16:05:47 ipsec IPSEC: : proposal #1
16:05:47 ipsec IPSEC: : enc: aes256-cbc
16:05:47 ipsec IPSEC: : auth: sha1
16:05:47 ipsec IPSEC: : dh: modp1536
16:05:47 ipsec IPSEC: : adding payload: NONCE
16:05:47 ipsec,debug IPSEC: : => (size 0x1c)
16:05:47 ipsec,debug IPSEC: : 0000001c b0a0d7e5 6b2a1451 bdff7a14 66d97474 92a447bb 172ce0e5
16:05:47 ipsec IPSEC: : adding payload: KE
16:05:47 ipsec,debug IPSEC: : => (size 0xc8)
16:05:47 ipsec,debug IPSEC: : 000000c8 00050000 eb20e1e0 9a4e140c c322bd29 c4f69bcc 42c9c25f 33b707b6
16:05:47 ipsec,debug IPSEC: : e8ea992b c238308f c2749c99 714d0b8d b63d62f2 4b8f5419 6c2ca92c b69370be
16:05:47 ipsec,debug IPSEC: : 96622dd5 ffca10e3 3eef6936 53abaccc 035a807b 1dae7db5 cc736dae 67b07b0a
16:05:47 ipsec,debug IPSEC: : 38aedef6 0b4f66c4 6c61deee 500de734 1b414739 b4740586 a95ae4fd 9716709a
16:05:47 ipsec,debug IPSEC: : 8c7dba46 173a65ac 31e79e79 01f071db 539b82fd 26932d11 90025461 f9c15ce6
16:05:47 ipsec,debug IPSEC: : 05506c43 b96129db d8aca88f 8aa843a4 2b9fdc10 937cd4bc eb8d8cc9 6a6c6d75
16:05:47 ipsec,debug IPSEC: : ffce250d 7d76dada
16:05:47 ipsec IPSEC: : adding payload: SA
16:05:47 ipsec,debug IPSEC: : => (size 0x34)
16:05:47 ipsec,debug IPSEC: : 00000034 00000030 01030404 089c38c0 0300000c 0100000c 800e0100 03000008
16:05:47 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:05:47 ipsec IPSEC: : initiator selector: 100.70.2.18
16:05:47 ipsec IPSEC: : adding payload: TS_I
16:05:47 ipsec,debug IPSEC: : => (size 0x18)
16:05:47 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:05:47 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:05:47 ipsec IPSEC: : adding payload: TS_R
16:05:47 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:05:47 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:6 89.31.7.243[500]
16:05:47 ipsec,debug IPSEC: : ===== sending 544 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:05:47 ipsec,debug IPSEC: : 1 times of 544 bytes message will be sent to 89.31.7.243[500]
16:05:47 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:05:47 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:6 89.31.7.243[500]
16:05:47 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:05:47 ipsec IPSEC: : processing payload: ENC
16:05:47 ipsec,debug IPSEC: : => iv (size 0x10)
16:05:47 ipsec,debug IPSEC: : 94c07aac ae47ee11 9803f651 b26859fa
16:05:47 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:05:47 ipsec,debug IPSEC: : 00000008 00000026
16:05:47 ipsec,debug IPSEC: : decrypted
16:05:47 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:05:47 ipsec IPSEC: : create child: initiator finish
16:05:47 ipsec IPSEC: : processing payloads: NOTIFY
16:05:47 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:05:47 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:05:52 ipsec IPSEC: : ph2 possible after ph1 creation
16:05:52 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:05:52 ipsec IPSEC: : init child continue
16:05:52 ipsec IPSEC: : offering proto: 3
16:05:52 ipsec IPSEC: : proposal #1
16:05:52 ipsec IPSEC: : enc: aes256-cbc
16:05:52 ipsec IPSEC: : auth: sha1
16:05:52 ipsec IPSEC: : dh: modp1536
16:05:52 ipsec IPSEC: : adding payload: NONCE
16:05:52 ipsec,debug IPSEC: : => (size 0x1c)
16:05:52 ipsec,debug IPSEC: : 0000001c 0b319176 dcb01f3a 316bd362 7e319278 02ff4d0d 9aeb4a6b
16:05:52 ipsec IPSEC: : adding payload: KE
16:05:52 ipsec,debug IPSEC: : => (size 0xc8)
16:05:52 ipsec,debug IPSEC: : 000000c8 00050000 78968127 68d00da8 87ca2e46 31b7c975 9711565c e56529e3
16:05:52 ipsec,debug IPSEC: : 0f5868a7 b215f61c 2765bf8f f1170ec1 6e378b73 c5fbc94d 1c3e8b25 631da3c4
16:05:52 ipsec,debug IPSEC: : 9945b0fc a127f2fa aeb3fc76 880f48a3 0cf872d9 2740bb37 b26cf645 f17520ec
16:05:52 ipsec,debug IPSEC: : 3f6f449b f5176ce8 179c2fe9 68377f66 b10f57ea a91d0780 635f5992 c8bd494b
16:05:52 ipsec,debug IPSEC: : 152e4572 12d8cfd5 7596968c 1032d51c 46e0b6c6 325682aa a1bdd13e 389ad3a3
16:05:52 ipsec,debug IPSEC: : 48c0e191 d070022e 237561ff 204e14af b27043b9 bd5a904c 505b5261 354a0ac5
16:05:52 ipsec,debug IPSEC: : 2832715d a8cefc6f
16:05:52 ipsec IPSEC: : adding payload: SA
16:05:52 ipsec,debug IPSEC: : => (size 0x34)
16:05:52 ipsec,debug IPSEC: : 00000034 00000030 01030404 01bb3033 0300000c 0100000c 800e0100 03000008
16:05:52 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:05:52 ipsec IPSEC: : initiator selector: 100.70.2.18
16:05:52 ipsec IPSEC: : adding payload: TS_I
16:05:52 ipsec,debug IPSEC: : => (size 0x18)
16:05:52 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:05:52 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:05:52 ipsec IPSEC: : adding payload: TS_R
16:05:52 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:05:52 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:7 89.31.7.243[500]
16:05:52 ipsec,debug IPSEC: : ===== sending 528 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:05:52 ipsec,debug IPSEC: : 1 times of 528 bytes message will be sent to 89.31.7.243[500]
16:05:52 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:05:52 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:7 89.31.7.243[500]
16:05:52 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:05:52 ipsec IPSEC: : processing payload: ENC
16:05:52 ipsec,debug IPSEC: : => iv (size 0x10)
16:05:52 ipsec,debug IPSEC: : 9db54c7f 821432af f28fdc0d c02be2ab
16:05:52 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:05:52 ipsec,debug IPSEC: : 00000008 00000026
16:05:52 ipsec,debug IPSEC: : decrypted
16:05:52 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:05:52 ipsec IPSEC: : create child: initiator finish
16:05:52 ipsec IPSEC: : processing payloads: NOTIFY
16:05:52 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:05:52 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:05:57 ipsec IPSEC: : ph2 possible after ph1 creation
16:05:57 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:05:57 ipsec IPSEC: : init child continue
16:05:57 ipsec IPSEC: : offering proto: 3
16:05:57 ipsec IPSEC: : proposal #1
16:05:57 ipsec IPSEC: : enc: aes256-cbc
16:05:57 ipsec IPSEC: : auth: sha1
16:05:57 ipsec IPSEC: : dh: modp1536
16:05:57 ipsec IPSEC: : adding payload: NONCE
16:05:57 ipsec,debug IPSEC: : => (size 0x1c)
16:05:57 ipsec,debug IPSEC: : 0000001c 47234f65 446352cf f4f35f6c 0196567e f349f401 a2ce6ddd
16:05:57 ipsec IPSEC: : adding payload: KE
16:05:57 ipsec,debug IPSEC: : => (size 0xc8)
16:05:57 ipsec,debug IPSEC: : 000000c8 00050000 ffd29717 0b704c96 f3d3b0b6 4025466c 5629a935 b8962baf
16:05:57 ipsec,debug IPSEC: : 0f9f4b22 72a42b17 9b8f2d5e a11452f9 e915c129 360645de f38ca589 c380fef0
16:05:57 ipsec,debug IPSEC: : f641295a 65a590bb 6747762a db08e2b9 3efd50d9 5a18b72b 724f5028 7edd2bf3
16:05:57 ipsec,debug IPSEC: : 3e506a4a e1ac2aaf 0c6c41ef 39885daa 3d757662 fbbd9faa 082fd7ce 13c065c6
16:05:57 ipsec,debug IPSEC: : ca967cd6 e263f050 f3155ae9 8c9a8132 3f6834a3 029b016e b0d979c1 ac6b7ddf
16:05:57 ipsec,debug IPSEC: : 1b130816 a3c44bae 52abf7ec a46b0e72 a1b9b0f4 1d0f99e8 1cb5965c 02592693
16:05:57 ipsec,debug IPSEC: : 8076aac6 d4b8d8f1
16:05:57 ipsec IPSEC: : adding payload: SA
16:05:57 ipsec,debug IPSEC: : => (size 0x34)
16:05:57 ipsec,debug IPSEC: : 00000034 00000030 01030404 0583d1a7 0300000c 0100000c 800e0100 03000008
16:05:57 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:05:57 ipsec IPSEC: : initiator selector: 100.70.2.18
16:05:57 ipsec IPSEC: : adding payload: TS_I
16:05:57 ipsec,debug IPSEC: : => (size 0x18)
16:05:57 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:05:57 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:05:57 ipsec IPSEC: : adding payload: TS_R
16:05:57 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:05:57 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:8 89.31.7.243[500]
16:05:57 ipsec,debug IPSEC: : ===== sending 512 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:05:57 ipsec,debug IPSEC: : 1 times of 512 bytes message will be sent to 89.31.7.243[500]
16:05:57 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:05:57 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:8 89.31.7.243[500]
16:05:57 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:05:57 ipsec IPSEC: : processing payload: ENC
16:05:57 ipsec,debug IPSEC: : => iv (size 0x10)
16:05:57 ipsec,debug IPSEC: : eab15fa0 59214c05 61c5b385 40a9a3e1
16:05:57 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:05:57 ipsec,debug IPSEC: : 00000008 00000026
16:05:57 ipsec,debug IPSEC: : decrypted
16:05:57 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:05:57 ipsec IPSEC: : create child: initiator finish
16:05:57 ipsec IPSEC: : processing payloads: NOTIFY
16:05:57 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:05:57 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:02 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:02 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:02 ipsec IPSEC: : init child continue
16:06:02 ipsec IPSEC: : offering proto: 3
16:06:02 ipsec IPSEC: : proposal #1
16:06:02 ipsec IPSEC: : enc: aes256-cbc
16:06:02 ipsec IPSEC: : auth: sha1
16:06:02 ipsec IPSEC: : dh: modp1536
16:06:02 ipsec IPSEC: : adding payload: NONCE
16:06:02 ipsec,debug IPSEC: : => (size 0x1c)
16:06:02 ipsec,debug IPSEC: : 0000001c 62d00bfe 5b5596e1 20862136 bedc128a a82ccdd1 32b758f3
16:06:02 ipsec IPSEC: : adding payload: KE
16:06:02 ipsec,debug IPSEC: : => (size 0xc8)
16:06:02 ipsec,debug IPSEC: : 000000c8 00050000 ded5d22c 739a1560 f5b41e74 6df8be89 a6398c25 036aef6b
16:06:02 ipsec,debug IPSEC: : d94c2f48 e0a1cce2 0ef48bc2 4c83eb22 c4ee8594 b740572c 891fa2bb e5daf0ea
16:06:02 ipsec,debug IPSEC: : f5f747d1 f803407d 38655c8d 4656232b 6c4846b1 6c4ace0e eaa698db 6f031534
16:06:02 ipsec,debug IPSEC: : d8c33967 9db8eb0e eeaa7ab8 18a06179 0d507303 3588a7ee 8662e713 584db858
16:06:02 ipsec,debug IPSEC: : 674992c6 e8f5b11b e19913ad 87081eb4 b0bc8b3c a93e5f3a 8bf912cb b9a3ebfb
16:06:02 ipsec,debug IPSEC: : 58a49c0c 5b90c6e0 d8703325 d5013fd2 f62862fa 18e1d45b 968a4b33 8d912241
16:06:02 ipsec,debug IPSEC: : 16ae6781 1411ac1b
16:06:02 ipsec IPSEC: : adding payload: SA
16:06:02 ipsec,debug IPSEC: : => (size 0x34)
16:06:02 ipsec,debug IPSEC: : 00000034 00000030 01030404 0268efed 0300000c 0100000c 800e0100 03000008
16:06:02 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:02 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:02 ipsec IPSEC: : adding payload: TS_I
16:06:02 ipsec,debug IPSEC: : => (size 0x18)
16:06:02 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:02 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:02 ipsec IPSEC: : adding payload: TS_R
16:06:02 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:02 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:9 89.31.7.243[500]
16:06:02 ipsec,debug IPSEC: : ===== sending 480 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:06:02 ipsec,debug IPSEC: : 1 times of 480 bytes message will be sent to 89.31.7.243[500]
16:06:02 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:06:02 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:9 89.31.7.243[500]
16:06:02 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:02 ipsec IPSEC: : processing payload: ENC
16:06:02 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:02 ipsec,debug IPSEC: : 2f86dbf7 0f71b6e1 32a339f5 de6ea7c3
16:06:02 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:02 ipsec,debug IPSEC: : 00000008 00000026
16:06:02 ipsec,debug IPSEC: : decrypted
16:06:02 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:02 ipsec IPSEC: : create child: initiator finish
16:06:02 ipsec IPSEC: : processing payloads: NOTIFY
16:06:02 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:02 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:07 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:07 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:07 ipsec IPSEC: : init child continue
16:06:07 ipsec IPSEC: : offering proto: 3
16:06:07 ipsec IPSEC: : proposal #1
16:06:07 ipsec IPSEC: : enc: aes256-cbc
16:06:07 ipsec IPSEC: : auth: sha1
16:06:07 ipsec IPSEC: : dh: modp1536
16:06:07 ipsec IPSEC: : adding payload: NONCE
16:06:07 ipsec,debug IPSEC: : => (size 0x1c)
16:06:07 ipsec,debug IPSEC: : 0000001c 3b904bba 9087cce3 28907b63 4f6dcf68 fd9dfa10 bbe72069
16:06:07 ipsec IPSEC: : adding payload: KE
16:06:07 ipsec,debug IPSEC: : => (size 0xc8)
16:06:07 ipsec,debug IPSEC: : 000000c8 00050000 703e5fd1 716ce2ac acbb2de2 0e2e7902 5e23d49f 0ccdee7e
16:06:07 ipsec,debug IPSEC: : 4ecce383 549d994c 6576ac28 c1920aa3 6a1569b4 791758ce f0595ce3 ef7cd3d2
16:06:07 ipsec,debug IPSEC: : 5c3b1486 ca703d28 ecba4ccd 3a3d9f7b 1e14da0d d68e263f 39f26e4a 96256231
16:06:07 ipsec,debug IPSEC: : 8da24003 21f2eab1 7c02a3fc 20dd6f67 92e58c4d 0c304473 b8fc5353 23fdd82e
16:06:07 ipsec,debug IPSEC: : 83039726 af4a0a58 d5a7b726 5888390f 16abc605 18853e2f 89721e84 2c3df7a5
16:06:07 ipsec,debug IPSEC: : b82010cb abc5d2a7 4ae06bec ad5abd33 278c6676 3b694151 fbfa1cf6 b7bfd486
16:06:07 ipsec,debug IPSEC: : 2226aeb5 89c8ad68
16:06:07 ipsec IPSEC: : adding payload: SA
16:06:07 ipsec,debug IPSEC: : => (size 0x34)
16:06:07 ipsec,debug IPSEC: : 00000034 00000030 01030404 098919f5 0300000c 0100000c 800e0100 03000008
16:06:07 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:07 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:07 ipsec IPSEC: : adding payload: TS_I
16:06:07 ipsec,debug IPSEC: : => (size 0x18)
16:06:07 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:07 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:07 ipsec IPSEC: : adding payload: TS_R
16:06:07 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:07 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:10 89.31.7.243[500]
16:06:07 ipsec,debug IPSEC: : ===== sending 544 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:06:07 ipsec,debug IPSEC: : 1 times of 544 bytes message will be sent to 89.31.7.243[500]
16:06:07 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:06:07 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:10 89.31.7.243[500]
16:06:07 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:07 ipsec IPSEC: : processing payload: ENC
16:06:07 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:07 ipsec,debug IPSEC: : 5895b23e 9f7e4a2b 92616923 7cf129b8
16:06:07 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:07 ipsec,debug IPSEC: : 00000008 00000026
16:06:07 ipsec,debug IPSEC: : decrypted
16:06:07 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:07 ipsec IPSEC: : create child: initiator finish
16:06:07 ipsec IPSEC: : processing payloads: NOTIFY
16:06:07 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:07 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:12 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:12 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:12 ipsec IPSEC: : init child continue
16:06:12 ipsec IPSEC: : offering proto: 3
16:06:12 ipsec IPSEC: : proposal #1
16:06:12 ipsec IPSEC: : enc: aes256-cbc
16:06:12 ipsec IPSEC: : auth: sha1
16:06:12 ipsec IPSEC: : dh: modp1536
16:06:12 ipsec IPSEC: : adding payload: NONCE
16:06:12 ipsec,debug IPSEC: : => (size 0x1c)
16:06:12 ipsec,debug IPSEC: : 0000001c edc3217a 3bb7fef4 31eb9005 ff441df2 d4f1c34c df3a94f7
16:06:12 ipsec IPSEC: : adding payload: KE
16:06:12 ipsec,debug IPSEC: : => (size 0xc8)
16:06:12 ipsec,debug IPSEC: : 000000c8 00050000 297ea63f 4993fc84 c9548eef 34e791e3 f9927d5c eb68e628
16:06:12 ipsec,debug IPSEC: : 302ef2fe 784c0024 b7007e57 4a40f88f 52b29806 fffb1450 d133affe 81a34631
16:06:12 ipsec,debug IPSEC: : e2c7e8a2 5c3dc8f4 f443103f 29ba8921 1c327b90 28a84fa7 c23d5a6e 80eccf45
16:06:12 ipsec,debug IPSEC: : d3068c8c 68ddc81c 2ddccb24 03d820a7 97500003 9d9d31c9 52c072d9 dbe0c050
16:06:12 ipsec,debug IPSEC: : af7143d5 6b128dc6 13b9bae8 e0eb447e c3af0f29 5b509549 ac8311c5 d6a3fd0e
16:06:12 ipsec,debug IPSEC: : 611616e1 c9fe01f0 bdc31d67 0ead479c 2db77555 db6724ea 53650a61 1d780ec3
16:06:12 ipsec,debug IPSEC: : be41481c bd549029
16:06:12 ipsec IPSEC: : adding payload: SA
16:06:12 ipsec,debug IPSEC: : => (size 0x34)
16:06:12 ipsec,debug IPSEC: : 00000034 00000030 01030404 0fbe9263 0300000c 0100000c 800e0100 03000008
16:06:12 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:12 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:12 ipsec IPSEC: : adding payload: TS_I
16:06:12 ipsec,debug IPSEC: : => (size 0x18)
16:06:12 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:12 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:12 ipsec IPSEC: : adding payload: TS_R
16:06:12 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:12 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:11 89.31.7.243[500]
16:06:12 ipsec,debug IPSEC: : ===== sending 480 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:06:12 ipsec,debug IPSEC: : 1 times of 480 bytes message will be sent to 89.31.7.243[500]
16:06:12 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:06:12 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:11 89.31.7.243[500]
16:06:12 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:12 ipsec IPSEC: : processing payload: ENC
16:06:12 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:12 ipsec,debug IPSEC: : a92add3c df1d7800 e0621be1 95be5317
16:06:12 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:12 ipsec,debug IPSEC: : 00000008 00000026
16:06:12 ipsec,debug IPSEC: : decrypted
16:06:12 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:12 ipsec IPSEC: : create child: initiator finish
16:06:12 ipsec IPSEC: : processing payloads: NOTIFY
16:06:12 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:12 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:17 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:17 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:17 ipsec IPSEC: : init child continue
16:06:17 ipsec IPSEC: : offering proto: 3
16:06:17 ipsec IPSEC: : proposal #1
16:06:17 ipsec IPSEC: : enc: aes256-cbc
16:06:17 ipsec IPSEC: : auth: sha1
16:06:17 ipsec IPSEC: : dh: modp1536
16:06:17 ipsec IPSEC: : adding payload: NONCE
16:06:17 ipsec,debug IPSEC: : => (size 0x1c)
16:06:17 ipsec,debug IPSEC: : 0000001c ee94a5cf 694f01cd 60b77069 296254b4 ec962c1d 196f0f45
16:06:17 ipsec IPSEC: : adding payload: KE
16:06:17 ipsec,debug IPSEC: : => (size 0xc8)
16:06:17 ipsec,debug IPSEC: : 000000c8 00050000 98ebd2ae 311d13d3 cc671bf5 0528e31e 8e66ae0a 430075f5
16:06:17 ipsec,debug IPSEC: : e434ee82 d1cb9a92 77d32248 7c1e5563 615c44ce af395406 4ba2f551 bff0c14d
16:06:17 ipsec,debug IPSEC: : 250ed62e 2fac2d35 ac2e07a2 348c1372 3c2beffa 3fbbc3ef c4528ca6 30042239
16:06:17 ipsec,debug IPSEC: : 6d7b9d58 cc3b0d11 51026de3 5da96895 d18280e1 9e3a6914 a4a11a1a 8c1bd72d
16:06:17 ipsec,debug IPSEC: : 5e4f47ac 2414e4ec d6aa4e0a 813830cf dd5827d8 b4584e30 6bf8c3ef c42aab12
16:06:17 ipsec,debug IPSEC: : dc65e390 86e84510 7145a910 1bb3f2bd bbdafbbf 42d76c04 2f642ab7 85ff0265
16:06:17 ipsec,debug IPSEC: : 99b5c766 c94aa684
16:06:17 ipsec IPSEC: : adding payload: SA
16:06:17 ipsec,debug IPSEC: : => (size 0x34)
16:06:17 ipsec,debug IPSEC: : 00000034 00000030 01030404 02287ab1 0300000c 0100000c 800e0100 03000008
16:06:17 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:17 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:17 ipsec IPSEC: : adding payload: TS_I
16:06:17 ipsec,debug IPSEC: : => (size 0x18)
16:06:17 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:17 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:17 ipsec IPSEC: : adding payload: TS_R
16:06:17 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:17 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:12 89.31.7.243[500]
16:06:17 ipsec,debug IPSEC: : ===== sending 544 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:06:17 ipsec,debug IPSEC: : 1 times of 544 bytes message will be sent to 89.31.7.243[500]
16:06:17 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:06:17 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:12 89.31.7.243[500]
16:06:17 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:17 ipsec IPSEC: : processing payload: ENC
16:06:17 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:17 ipsec,debug IPSEC: : f9e5d272 ec0d8c07 a38837ac f53598c2
16:06:17 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:17 ipsec,debug IPSEC: : 00000008 00000026
16:06:17 ipsec,debug IPSEC: : decrypted
16:06:17 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:17 ipsec IPSEC: : create child: initiator finish
16:06:17 ipsec IPSEC: : processing payloads: NOTIFY
16:06:17 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:17 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:22 ipsec,info killing ike2 SA: 84.134.88.235[500]-89.31.7.243[500] spi:0ae41558038ac834:891190d5eacc1173
16:06:22 ipsec,info IPSEC: : killing ike2 SA: 84.134.88.235[500]-89.31.7.243[500] spi:0ae41558038ac834:891190d5eacc1173
16:06:22 ipsec IPSEC: : IPsec-SA killing: 89.31.7.243[500]->84.134.88.235[500] spi=0x409fbe5
16:06:22 ipsec IPSEC: : IPsec-SA killing: 84.134.88.235[500]->89.31.7.243[500] spi=0xc9baffa1
16:06:22 ipsec IPSEC: : adding payload: DELETE
16:06:22 ipsec,debug IPSEC: : => (size 0x8)
16:06:22 ipsec,debug IPSEC: : 00000008 01000000
16:06:22 ipsec IPSEC: : <- ike2 request, exchange: INFORMATIONAL:13 89.31.7.243[500]
16:06:22 ipsec,debug IPSEC: : ===== sending 272 bytes from 84.134.88.235[500] to 89.31.7.243[500]
16:06:22 ipsec,debug IPSEC: : 1 times of 272 bytes message will be sent to 89.31.7.243[500]
16:06:22 system,info ipsec peer swyx changed by admin
16:06:22 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 84.134.88.235[500]
16:06:22 ipsec IPSEC: : -> ike2 reply, exchange: INFORMATIONAL:13 89.31.7.243[500]
16:06:22 ipsec IPSEC: : SPI 34c88a035815e40a not registered for 89.31.7.243[500]
16:06:24 ipsec IPSEC: : ike2 starting for: 89.31.7.243
16:06:24 ipsec IPSEC: : adding payload: NONCE
16:06:24 ipsec,debug IPSEC: : => (size 0x1c)
16:06:24 ipsec,debug IPSEC: : 0000001c 4ed1a5f9 ba048f42 93a612d0 917bdf71 5c6d1f5b 70f393f4
16:06:24 ipsec IPSEC: : adding payload: KE
16:06:24 ipsec,debug IPSEC: : => (size 0xc8)
16:06:24 ipsec,debug IPSEC: : 000000c8 00050000 ecf9e672 95f093f0 a953ea0b 280ba8b6 7979506e 54cece3e
16:06:24 ipsec,debug IPSEC: : b0269451 c4822a3c 3f3fddb6 8ba9bf08 782621ea 7f0bf0a4 5e923bb9 bb2ad349
16:06:24 ipsec,debug IPSEC: : a882b52d eedc0daf e4193f22 f505f813 ccdc9686 20010c07 5c9ea09f 56d18b39
16:06:24 ipsec,debug IPSEC: : be525354 57072903 c5662b93 4a957347 2f084d70 cc3d7154 a973cdeb 5e35918c
16:06:24 ipsec,debug IPSEC: : 696eee58 5ad6b0a3 31fe1a9a 5ccb8a94 074f5a26 7faf23a1 ca5848ae 3e38554c
16:06:24 ipsec,debug IPSEC: : e531cff7 aecf7a6d 52fa6ec0 ceff78e3 197445ec 17784571 5d4fc369 df76e967
16:06:24 ipsec,debug IPSEC: : efe78155 823d01ad
16:06:24 ipsec IPSEC: : adding payload: SA
16:06:24 ipsec,debug IPSEC: : => (size 0x30)
16:06:24 ipsec,debug IPSEC: : 00000030 0000002c 01010004 0300000c 0100000c 800e0100 03000008 02000005
16:06:24 ipsec,debug IPSEC: : 03000008 0300000c 00000008 04000005
16:06:24 ipsec IPSEC: : <- ike2 request, exchange: SA_INIT:0 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : ===== sending 304 bytes from 192.168.42.1[500] to 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : 1 times of 304 bytes message will be sent to 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : ===== received 398 bytes from 89.31.7.243[500] to 192.168.42.1[500]
16:06:24 ipsec IPSEC: : -> ike2 reply, exchange: SA_INIT:0 89.31.7.243[500]
16:06:24 ipsec IPSEC: : ike2 initialize recv
16:06:24 ipsec IPSEC: : payload seen: SA (48 bytes)
16:06:24 ipsec IPSEC: : payload seen: KE (200 bytes)
16:06:24 ipsec IPSEC: : payload seen: NONCE (36 bytes)
16:06:24 ipsec IPSEC: : payload seen: VID (23 bytes)
16:06:24 ipsec,debug IPSEC: : 434953434f2d44454c4554452d524541534f4e
16:06:24 ipsec IPSEC: : payload seen: VID (19 bytes)
16:06:24 ipsec,debug IPSEC: : 434953434f56504e2d5245562d3032
16:06:24 ipsec,debug IPSEC: : 434953434f2d44594e414d49432d524f555445
16:06:24 ipsec IPSEC: : payload seen: VID (21 bytes)
16:06:24 ipsec,debug IPSEC: : 464c455856504e2d535550504f52544544
16:06:24 ipsec IPSEC: : processing payload: NONCE
16:06:24 ipsec IPSEC: : processing payload: SA
16:06:24 ipsec IPSEC: : IKE Protocol: IKE
16:06:24 ipsec IPSEC: : proposal #1
16:06:24 ipsec IPSEC: : enc: aes256-cbc
16:06:24 ipsec IPSEC: : prf: hmac-sha256
16:06:24 ipsec IPSEC: : auth: sha256
16:06:24 ipsec IPSEC: : dh: modp1536
16:06:24 ipsec IPSEC: : matched proposal:
16:06:24 ipsec IPSEC: : processing payload: KE
16:06:24 ipsec,debug IPSEC: : => shared secret (size 0xc0)
16:06:24 ipsec,debug IPSEC: : cbe24586 98a22b42 3a02c455 09e7a3d5 637ab14a 3bf8214b 9446e88a 9f59cf1e
16:06:24 ipsec,debug IPSEC: : fa754096 1edd2544 232145a1 c70c0286 ff595470 796537f8 63c0078b 70afde6a
16:06:24 ipsec,debug IPSEC: : f3d7a462 907ef550 379a89b9 ea470a29 3dacfdb8 a26588e3 23b5257f 909aa6ae
16:06:24 ipsec,debug IPSEC: : f06d0a2e 1acc0d8e 6c979da0 ddb76036 0cebbc5f fb319895 e3187252 6f53dd34
16:06:24 ipsec,debug IPSEC: : bbababe5 ddcab197 76a67388 a015379b 1d5d632b d021fe8c 96a8e93c b5dc4ca5
16:06:24 ipsec,debug IPSEC: : f3305b2d 91e57484 79127848 8986e4a9 8ceb2aab fe424e3a 01a24be9 b5fac1d9
16:06:24 ipsec,debug IPSEC: : => skeyseed (size 0x20)
16:06:24 ipsec,debug IPSEC: : d3f6c4bd 637b4b7d 5e40e547 08a05d04 3c9cf3e6 10298c3e 603a8fa4 8d5ab148
16:06:24 ipsec,debug IPSEC: : => keymat (size 0x20)
16:06:24 ipsec,debug IPSEC: : a37b0c7d c797a170 9a7148c8 8dabd867 0995cf81 e8e00049 c67a5ce9 f94a3c2d
16:06:24 ipsec,debug IPSEC: : => SK_ai (size 0x20)
16:06:24 ipsec,debug IPSEC: : d206f41b 1dfcd00b 176a3ed4 edcbfeab 6dc71bfa af316715 c40d4a8b 43c2d6b7
16:06:24 ipsec,debug IPSEC: : => SK_ar (size 0x20)
16:06:24 ipsec,debug IPSEC: : d2f440d9 0c547c5f 4cc8f87f 3d910c4c 2e1d6c2e 6dd4c68a 8541cacb f5cc2e81
16:06:24 ipsec,debug IPSEC: : => SK_ei (size 0x20)
16:06:24 ipsec,debug IPSEC: : 37313cf2 88439b24 31e89d97 fdbb45cd f9e2a67f a8ec827d f9804bca f8602b29
16:06:24 ipsec,debug IPSEC: : => SK_er (size 0x20)
16:06:24 ipsec,debug IPSEC: : bfda7f03 6512b128 0a711ce6 4f1eafbc d1833787 92e6d5b3 1ce13f9a e9e17eac
16:06:24 ipsec,debug IPSEC: : => SK_pi (size 0x20)
16:06:24 ipsec,debug IPSEC: : d82708d0 c5b1f9cd af730ea6 d45a5151 80b42126 604c2259 9ec69f09 2fc09824
16:06:24 ipsec,debug IPSEC: : => SK_pr (size 0x20)
16:06:24 ipsec,debug IPSEC: : 3162d169 54f2fea0 2dc2d72d 8a77ca44 457c1caa 77ae76a7 d1394547 ac679692
16:06:24 ipsec,info new ike2 SA (I): 192.168.42.1[500]-89.31.7.243[500] spi:3db88fe22e534ad2:46e0fa4582b98060
16:06:24 ipsec,info IPSEC: : new ike2 SA (I): 192.168.42.1[500]-89.31.7.243[500] spi:3db88fe22e534ad2:46e0fa4582b98060
16:06:24 ipsec IPSEC: : processing payloads: NOTIFY (none found)
16:06:24 ipsec IPSEC: : init child for policy: 192.168.42.0/24 <=> 100.70.2.18
16:06:24 ipsec IPSEC: : init child continue
16:06:24 ipsec IPSEC: : offering proto: 3
16:06:24 ipsec IPSEC: : auth: sha1
16:06:24 ipsec IPSEC: : ID_I (RFC822): office9596@scouter.de
16:06:24 ipsec IPSEC: : adding payload: ID_I
16:06:24 ipsec,debug IPSEC: : => (size 0x1d)
16:06:24 ipsec,debug IPSEC: : 0000001d 03000000 6f666669 63653935 39364073 636f7574 65722e64 65
16:06:24 ipsec,debug IPSEC: : => auth nonce (size 0x20)
16:06:24 ipsec,debug IPSEC: : 1c6004e9 f1fbc118 923485e7 cce49449 b176363c 24eb7373 496b18ec 40b7db2e
16:06:24 ipsec,debug IPSEC: : => SK_p (size 0x20)
16:06:24 ipsec,debug IPSEC: : => idhash (size 0x20)
16:06:24 ipsec,debug IPSEC: : 383dd0bc ee0ec785 252b004b b4a59454 94596bd0 46939262 c2087e56 fc41851f
16:06:24 ipsec,debug IPSEC: : => my auth (size 0x20)
16:06:24 ipsec,debug IPSEC: : 73324cc7 8c7f5813 ce17e00f 264760df 76562835 41f2ba06 eed79956 0796c243
16:06:24 ipsec IPSEC: : adding payload: AUTH
16:06:24 ipsec,debug IPSEC: : => (size 0x28)
16:06:24 ipsec,debug IPSEC: : 00000028 02000000 73324cc7 8c7f5813 ce17e00f 264760df 76562835 41f2ba06
16:06:24 ipsec,debug IPSEC: : eed79956 0796c243
16:06:24 ipsec IPSEC: : ID_R (RFC822): vpn@swyxon.com
16:06:24 ipsec IPSEC: : adding payload: ID_R
16:06:24 ipsec,debug IPSEC: : => (size 0x16)
16:06:24 ipsec,debug IPSEC: : 00000016 03000000 76706e40 73777978 6f6e2e63 6f6d
16:06:24 ipsec IPSEC: : adding notify: INITIAL_CONTACT
16:06:24 ipsec,debug IPSEC: : => (size 0x8)
16:06:24 ipsec,debug IPSEC: : 00000008 00004000
16:06:24 ipsec,debug IPSEC: : => (size 0x2c)
16:06:24 ipsec,debug IPSEC: : 0000002c 00000028 01030403 03f22b36 0300000c 0100000c 800e0100 03000008
16:06:24 ipsec,debug IPSEC: : 03000002 00000008 05000000
16:06:24 ipsec IPSEC: : initiator selector: 192.168.42.0/24
16:06:24 ipsec IPSEC: : adding payload: TS_I
16:06:24 ipsec,debug IPSEC: : => (size 0x18)
16:06:24 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:24 ipsec IPSEC: : responder selector: 100.70.2.18
16:06:24 ipsec IPSEC: : adding payload: TS_R
16:06:24 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:24 ipsec IPSEC: : <- ike2 request, exchange: AUTH:1 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : ===== sending 336 bytes from 192.168.42.1[500] to 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : 1 times of 336 bytes message will be sent to 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : ===== received 272 bytes from 89.31.7.243[500] to 192.168.42.1[500]
16:06:24 ipsec IPSEC: : -> ike2 reply, exchange: AUTH:1 89.31.7.243[500]
16:06:24 ipsec IPSEC: : payload seen: ENC (244 bytes)
16:06:24 ipsec IPSEC: : processing payload: ENC
16:06:24 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:24 ipsec,debug IPSEC: : f51efca3 42006404 1d8075fc 246dd36e
16:06:24 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0xca)
16:06:24 ipsec,debug IPSEC: : 24000014 47e0fb45 918e7327 6a5d95eb 3d058e3b 27000016 03000000 76706e40
16:06:24 ipsec,debug IPSEC: : 73777978 6f6e2e63 6f6d2100 00280200 00004c6a 61d01c8d 6261dbfc 0700b619
16:06:24 ipsec,debug IPSEC: : af0bb19c 8dfa6593 b188fc93 8d5d2de1 06f92c00 002c0000 00280103 0403f61c
16:06:24 ipsec,debug IPSEC: : 99fc0300 000c0100 000c800e 01000300 00080300 00020000 00080500 00002d00
16:06:24 ipsec,debug IPSEC: : 00180100 00000700 00100000 ffffc0a8 2a00c0a8 2aff2900 00180100 00000700
16:06:24 ipsec,debug IPSEC: : 00100000 ffff6446 02126446 02122900 000c0000 40010000 00052900 00080000
16:06:24 ipsec,debug IPSEC: : 400a0000 00080000 400b
16:06:24 ipsec,debug IPSEC: : decrypted
16:06:24 ipsec IPSEC: : payload seen: VID (20 bytes)
16:06:24 ipsec,debug IPSEC: : 47e0fb45918e73276a5d95eb3d058e3b
16:06:24 ipsec IPSEC: : payload seen: ID_R (22 bytes)
16:06:24 ipsec IPSEC: : payload seen: AUTH (40 bytes)
16:06:24 ipsec IPSEC: : payload seen: SA (44 bytes)
16:06:24 ipsec IPSEC: : payload seen: TS_I (24 bytes)
16:06:24 ipsec IPSEC: : payload seen: TS_R (24 bytes)
16:06:24 ipsec IPSEC: : payload seen: NOTIFY (12 bytes)
16:06:24 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:24 ipsec IPSEC: : notify: SET_WINDOW_SIZE
16:06:24 ipsec,debug IPSEC: : 00000005
16:06:24 ipsec IPSEC: : notify: ESP_TFC_PADDING_NOT_SUPPORTED
16:06:24 ipsec IPSEC: : notify: NON_FIRST_FRAGMENTS_ALSO
16:06:24 ipsec IPSEC: : ike auth: initiator finish
16:06:24 ipsec IPSEC: : processing payload: ID_R
16:06:24 ipsec IPSEC: : processing payload: AUTH
16:06:24 ipsec IPSEC: : requested auth method: SKEY
16:06:24 ipsec,debug IPSEC: : => peer's auth (size 0x20)
16:06:24 ipsec,debug IPSEC: : 4c6a61d0 1c8d6261 dbfc0700 b619af0b b19c8dfa 6593b188 fc938d5d 2de106f9
16:06:24 ipsec,debug IPSEC: : => auth nonce (size 0x18)
16:06:24 ipsec,debug IPSEC: : 4ed1a5f9 ba048f42 93a612d0 917bdf71 5c6d1f5b 70f393f4
16:06:24 ipsec,debug IPSEC: : 5f9cd683 1a4a5881 63a897db e1ebaa17 fe14f08e a8ee2ec9 248ef36b f05743a8
16:06:24 ipsec,debug IPSEC: : => calculated peer's AUTH (size 0x20)
16:06:24 ipsec,info,account peer authorized: 192.168.42.1[500]-89.31.7.243[500] spi:3db88fe22e534ad2:46e0fa4582b98060
16:06:24 ipsec,info,account IPSEC: : peer authorized: 192.168.42.1[500]-89.31.7.243[500] spi:3db88fe22e534ad2:46e0fa4582b98060
16:06:24 ipsec IPSEC: : peer selected tunnel mode
16:06:24 ipsec IPSEC: : processing payload: TS_I
16:06:24 ipsec IPSEC: : 192.168.42.0/24
16:06:24 ipsec IPSEC: : processing payload: TS_R
16:06:24 ipsec IPSEC: : 100.70.2.18
16:06:24 ipsec IPSEC: : my vs peer's selectors:
16:06:24 ipsec IPSEC: : 192.168.42.0/24 vs 192.168.42.0/24
16:06:24 ipsec IPSEC: : 100.70.2.18 vs 100.70.2.18
16:06:24 ipsec IPSEC: : IKE Protocol: ESP
16:06:24 ipsec,debug IPSEC: : => child keymat (size 0x80)
16:06:24 ipsec,debug IPSEC: : b3ed27f9 431a8335 f9e9a724 bd027714 e9506afa 1e0d15ca a6f7e5fd 35b52d95
16:06:24 ipsec,debug IPSEC: : 3a550d13 5734de34 e7c3463e d2734fb6 918b69c5 1156f1c4 72978af5 f8782b75
16:06:24 ipsec,debug IPSEC: : 5764a564 2b2bf1d8 94bf8b85 3f811a90 7f191f78 72b7207d 31bff936 89a6ce77
16:06:24 ipsec,debug IPSEC: : c0facc6e 114692a2 9671e1ed d1804f56 9a004ac3 17e76526 61f41254 e12c04a9
16:06:24 ipsec IPSEC: : IPsec-SA established: 89.31.7.243[500]->192.168.42.1[500] spi=0x3f22b36
16:06:24 ipsec IPSEC: : IPsec-SA established: 192.168.42.1[500]->89.31.7.243[500] spi=0xf61c99fc
16:06:24 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:24 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:24 ipsec,debug IPSEC: : 0000001c 3cd429f5 ca4d6324 7637bd93 bd8ae22a b78edc38 bdf84841
16:06:24 ipsec,debug IPSEC: : 000000c8 00050000 f8f47cec 77a70bbc 1edcd1e6 3b85eaf5 5a03e061 914dea67
16:06:24 ipsec,debug IPSEC: : f7cf005f 976010ea ce1a154f 62cc7522 cd3fc64b 114b6e42 db16bde2 f42cfbcd
16:06:24 ipsec,debug IPSEC: : 3fa0f3c8 4dcbde0a 620fe250 5ec1f974 9214e3ec 5192e2c9 a3eeaf5c 00016e32
16:06:24 ipsec,debug IPSEC: : 2acef4fe 0b1087d9 2f25ba49 087ac487 b3c7666b 1539c8b3 16fd914a 404fa192
16:06:24 ipsec,debug IPSEC: : 94114f98 5e141041 690872db 97b20b41 31942aeb d9b1e83c 7aa574f8 fefabda9
16:06:24 ipsec,debug IPSEC: : 639e8b28 2ab5695f 1187e24e fa93a4bf 28dd0bf5 526790d5 ed832bb2 0634cdca
16:06:24 ipsec,debug IPSEC: : d5eacf35 2cee7c0a
16:06:24 ipsec,debug IPSEC: : => (size 0x34)
16:06:24 ipsec,debug IPSEC: : 00000034 00000030 01030404 07044624 0300000c 0100000c 800e0100 03000008
16:06:24 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:24 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:24 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:24 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:2 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : ===== sending 544 bytes from 192.168.42.1[500] to 89.31.7.243[500]
16:06:24 ipsec,debug IPSEC: : 1 times of 544 bytes message will be sent to 89.31.7.243[500]
16:06:29 ipsec IPSEC: : retransmit
16:06:29 ipsec,debug IPSEC: : ===== sending 544 bytes from 192.168.42.1[500] to 89.31.7.243[500]
16:06:29 ipsec,debug IPSEC: : 1 times of 544 bytes message will be sent to 89.31.7.243[500]
16:06:29 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 192.168.42.1[500]
16:06:29 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:2 89.31.7.243[500]
16:06:29 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:29 ipsec IPSEC: : processing payload: ENC
16:06:29 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:29 ipsec,debug IPSEC: : 62c3b476 201e0a99 c698402a ecdd5e3d
16:06:29 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:29 ipsec,debug IPSEC: : 00000008 00000026
16:06:29 ipsec,debug IPSEC: : decrypted
16:06:29 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:29 ipsec IPSEC: : create child: initiator finish
16:06:29 ipsec IPSEC: : processing payloads: NOTIFY
16:06:29 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:29 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:34 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:34 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:34 ipsec IPSEC: : init child continue
16:06:34 ipsec IPSEC: : offering proto: 3
16:06:34 ipsec IPSEC: : proposal #1
16:06:34 ipsec IPSEC: : enc: aes256-cbc
16:06:34 ipsec IPSEC: : auth: sha1
16:06:34 ipsec IPSEC: : dh: modp1536
16:06:34 ipsec IPSEC: : adding payload: NONCE
16:06:34 ipsec,debug IPSEC: : => (size 0x1c)
16:06:34 ipsec,debug IPSEC: : 0000001c 5a0e0bba d011ad0b 2943823d 647f24b1 a18e412d 19767c79
16:06:34 ipsec IPSEC: : adding payload: KE
16:06:34 ipsec,debug IPSEC: : => (size 0xc8)
16:06:34 ipsec,debug IPSEC: : 000000c8 00050000 f9ca46ce 5bf778f3 ac426958 922356d6 475f847c 3bda01c1
16:06:34 ipsec,debug IPSEC: : 9dd5de69 bf6098b7 5a1e135a 42e7823e dabb2f07 0b883a2b 31949c12 5cea86bd
16:06:34 ipsec,debug IPSEC: : 0ee6170d 38371502 19b325c8 c5533627 eacc6456 889ce9d1 7d54ced3 8fd8e3e5
16:06:34 ipsec,debug IPSEC: : c5e522a5 6e5969bf af9c0133 cb0b920d faa21e7f ac165d1e 3bfb84c0 13f787e6
16:06:34 ipsec,debug IPSEC: : fa6d15db bc95f0a9 fb5c45a1 9422384a 5ab7b4ce 37cd3df9 0156b5e2 999438a0
16:06:34 ipsec,debug IPSEC: : 47dc9a66 e74c3de9 9eeb63e5 e75d8085 efb1b2c0 291d666f 9ec2d767 772d1c3e
16:06:34 ipsec,debug IPSEC: : b7b327ee 9ee6fd0d
16:06:34 ipsec IPSEC: : adding payload: SA
16:06:34 ipsec,debug IPSEC: : => (size 0x34)
16:06:34 ipsec,debug IPSEC: : 00000034 00000030 01030404 05698ae4 0300000c 0100000c 800e0100 03000008
16:06:34 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:34 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:34 ipsec IPSEC: : adding payload: TS_I
16:06:34 ipsec,debug IPSEC: : => (size 0x18)
16:06:34 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:34 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:34 ipsec IPSEC: : adding payload: TS_R
16:06:34 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:34 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:3 89.31.7.243[500]
16:06:34 ipsec,debug IPSEC: : ===== sending 496 bytes from 192.168.42.1[500] to 89.31.7.243[500]
16:06:34 ipsec,debug IPSEC: : 1 times of 496 bytes message will be sent to 89.31.7.243[500]
16:06:34 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 192.168.42.1[500]
16:06:34 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:3 89.31.7.243[500]
16:06:34 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:34 ipsec IPSEC: : processing payload: ENC
16:06:34 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:34 ipsec,debug IPSEC: : 5a2499b6 3dfd505a d027c447 7c09c175
16:06:34 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:34 ipsec,debug IPSEC: : 00000008 00000026
16:06:34 ipsec,debug IPSEC: : decrypted
16:06:34 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:34 ipsec IPSEC: : create child: initiator finish
16:06:34 ipsec IPSEC: : processing payloads: NOTIFY
16:06:34 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:34 ipsec IPSEC: : got error: TS_UNACCEPTABLE
16:06:39 ipsec IPSEC: : ph2 possible after ph1 creation
16:06:39 ipsec IPSEC: : init child for policy: 100.70.2.18 <=> 192.168.42.0/24
16:06:39 ipsec IPSEC: : init child continue
16:06:39 ipsec IPSEC: : offering proto: 3
16:06:39 ipsec IPSEC: : proposal #1
16:06:39 ipsec IPSEC: : enc: aes256-cbc
16:06:39 ipsec IPSEC: : auth: sha1
16:06:39 ipsec IPSEC: : dh: modp1536
16:06:39 ipsec IPSEC: : adding payload: NONCE
16:06:39 ipsec,debug IPSEC: : => (size 0x1c)
16:06:39 ipsec,debug IPSEC: : 0000001c 8c93519e 1ffa6eb9 b4ef7ed2 bd48b7b7 2c3e1a68 55c35437
16:06:39 ipsec IPSEC: : adding payload: KE
16:06:39 ipsec,debug IPSEC: : => (size 0xc8)
16:06:39 ipsec,debug IPSEC: : 000000c8 00050000 8f40e715 c022b26f e20614b2 f79a4a4d 16493260 a186a8cc
16:06:39 ipsec,debug IPSEC: : cd4c5b6c c963fde9 bc29d98e 92c5d0a5 559a5120 3c33cebf a7234271 31182e68
16:06:39 ipsec,debug IPSEC: : 6a842b57 04332003 dfbb0969 c3e17ba7 088d00bd 314ffef0 c24026de e29972f4
16:06:39 ipsec,debug IPSEC: : b507f1c0 41bec591 c0fd9f4e e08fbf36 13506cbf 6fc1c5a7 1fd74a04 97cea660
16:06:39 ipsec,debug IPSEC: : ccb0a96a fe7ea170 b57bab15 0fd62a07 b0639323 087edd2f fb009ac9 fc41f765
16:06:39 ipsec,debug IPSEC: : 3b44bc4e e5d41a74 bad22aff 1fc556b8 91817eda 3c431f1f 40bb93b7 20b4276a
16:06:39 ipsec,debug IPSEC: : a19939bf 6bf8a9d8
16:06:39 ipsec IPSEC: : adding payload: SA
16:06:39 ipsec,debug IPSEC: : => (size 0x34)
16:06:39 ipsec,debug IPSEC: : 00000034 00000030 01030404 0d6113df 0300000c 0100000c 800e0100 03000008
16:06:39 ipsec,debug IPSEC: : 03000002 03000008 04000005 00000008 05000000
16:06:39 ipsec IPSEC: : initiator selector: 100.70.2.18
16:06:39 ipsec IPSEC: : adding payload: TS_I
16:06:39 ipsec,debug IPSEC: : => (size 0x18)
16:06:39 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff 64460212 64460212
16:06:39 ipsec IPSEC: : responder selector: 192.168.42.0/24
16:06:39 ipsec IPSEC: : adding payload: TS_R
16:06:39 ipsec,debug IPSEC: : 00000018 01000000 07000010 0000ffff c0a82a00 c0a82aff
16:06:39 ipsec IPSEC: : <- ike2 request, exchange: CREATE_CHILD_SA:4 89.31.7.243[500]
16:06:39 ipsec,debug IPSEC: : ===== sending 528 bytes from 192.168.42.1[500] to 89.31.7.243[500]
16:06:39 ipsec,debug IPSEC: : 1 times of 528 bytes message will be sent to 89.31.7.243[500]
16:06:39 ipsec,debug IPSEC: : ===== received 80 bytes from 89.31.7.243[500] to 192.168.42.1[500]
16:06:39 ipsec IPSEC: : -> ike2 reply, exchange: CREATE_CHILD_SA:4 89.31.7.243[500]
16:06:39 ipsec IPSEC: : payload seen: ENC (52 bytes)
16:06:39 ipsec IPSEC: : processing payload: ENC
16:06:39 ipsec,debug IPSEC: : => iv (size 0x10)
16:06:39 ipsec,debug IPSEC: : 0012e34e d9730565 d8c71b4e 9540c719
16:06:39 ipsec,debug IPSEC: : => plain payload (trimmed) (size 0x8)
16:06:39 ipsec,debug IPSEC: : 00000008 00000026
16:06:39 ipsec,debug IPSEC: : decrypted
16:06:39 ipsec IPSEC: : payload seen: NOTIFY (8 bytes)
16:06:39 ipsec IPSEC: : create child: initiator finish
16:06:39 ipsec IPSEC: : processing payloads: NOTIFY
16:06:39 ipsec IPSEC: : notify: TS_UNACCEPTABLE
16:06:39 ipsec IPSEC: : got error: TS_UNACCEPTABLE
