Issues WAP-LTE-KIT
Hi all,
we are experiencing some issuess with this hardware.
This hardware comes with:
“R11e-LTE” modem
MikroTik_CP_2.160.000_v001" Revision.
Using this hardware we set a basic configuration and LTE links OK.If we configure a Public IP in LTE interface it works fine,but if we configure a LoopBack Interface it doesn’t work.
Same configuration works fine using same Hardware only changing LTE MODEM.Using same modem Model, only change Revision.
“R11e-LTE”
MikroTik_CP_2.160.000_v007" Revision.
Is there anyway to Upgrade revision or firmware ??
Thanks and regards
https://blog.effenberger.org/2018/06/09/firmware-des-mikrotik-r11e-lte-aktualisieren/
I have upgraded to version 008, it works, no issues.
@qbic:
what sort of speeds do you get?
I upgraded too and get consistently (much) less than 10 Mbps…
Anyway there is no easy way to check firmware version… so just FYI.
MD5 of MikroTik_CP_2.160.000_v008 firmware is 311468f9263593500b97de434b7ab19a
It depends on signal quality, but from 10 to 30 mbit… depending on operator. Im living in the city centre but in very very bad location, no visible cell towers around.
