Hi there!
- I need to configure Wi-Fi network with two VLANs. Clients in each network should be isolated between each other. I took as a base the config from the example, but I still can ping from network 192.168.10.0/24 to 192.168.20.0/24 and vice versa. Where I am wrong?
- Why interfaces wifi1 and wifi2 do not connected to CAPsMAN?
add admin-mac=D0:01:C0:B0:0B:00 auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
/interface wifi
# no connection to CAPsMAN
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap \
disabled=no
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap \
disabled=no
/interface vlan
add interface=bridge name=GUEST vlan-id=20
add interface=bridge name=MAIN vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi datapath
add bridge=bridge client-isolation=yes disabled=no name=MAIN vlan-id=10
add bridge=bridge client-isolation=yes disabled=no name=GUEST vlan-id=20
/interface wifi security
add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes \
group-encryption=ccmp group-key-update=40m name=Security_MAIN wps=disable
group-encryption=ccmp group-key-update=40m name=Security_GUEST wps=\
disable
/interface wifi configuration
add datapath=MAIN disabled=no name=MAIN security=Security_MAIN ssid=MAIN_Network
add datapath=GUEST disabled=no name=GUEST security=Security_GUEST ssid=GUEST_Network
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool2 ranges=192.168.20.2-192.168.20.254
add address-pool=dhcp_pool0 disabled=yes interface=bridge name=dhcp1
add address-pool=dhcp_pool1 interface=MAIN name=dhcp2
add address-pool=dhcp_pool2 interface=GUEST name=dhcp3
/disk settings
set auto-media-interface=bridge
add bridge=bridge comment=defconf disabled=yes interface=wifi1
add bridge=bridge comment=defconf disabled=yes interface=wifi2
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2,ether3,ether4,ether5 vlan-ids=10
add bridge=bridge tagged=bridge,ether2,ether3,ether4,ether5 vlan-ids=20
/interface wifi cap
set caps-man-addresses=127.0.0.1 enabled=yes
/interface wifi capsman
set enabled=yes interfaces=bridge package-path="" require-peer-certificate=no \
upgrade-policy=suggest-same-version
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=MAIN \
name-format=5G-%I slave-configurations=GUEST supported-bands=5ghz-ax
name-format=2G-%I slave-configurations=GUEST supported-bands=2ghz-ax
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
add address=192.168.10.1/24 interface=MAIN network=192.168.10.0
add address=192.168.20.1/24 interface=GUEST network=192.168.20.0
/ip dhcp-client
add comment=defconf default-route-tables=main interface=ether1 use-peer-dns=\
no
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.10.0/24 gateway=192.168.10.1
add address=192.168.20.0/24 gateway=192.168.20.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" \
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system note
set show-at-login=no
