Issues with Mikrotik acting as WG client
Hi All,
I’m having some issues in connect my hAPac2 to a WG server hosted in my house on a Unifi DM
I can connect with my PC and mobile without issues, but I can’t with the Mikrotik.
Here is my configuration (hopefully I don’t miss any important info
# 2023-10-31 11:33:12 by RouterOS 7.11.2
# software id = ZWBX-KG0E
add name=br-local
/interface wireless
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
set [ find default-name=wlan2 ] disabled=no ssid=MikroTik
/interface wireguard
add listen-port=13231 mtu=1420 name=WG1
/ip hotspot profile
add name=dhcp_pool1 ranges=10.0.0.2-10.0.0.254
add address-pool=dhcp_pool1 interface=br-local name=dhcp1
add bridge=br-local interface=ether2
add bridge=br-local interface=ether3
add bridge=br-local interface=ether4
add bridge=br-local interface=ether5
add bridge=br-local interface=wlan1
add bridge=br-local interface=wlan2
/interface wireguard peers
add allowed-address=192.168.50.1/32,192.168.50.5/32,0.0.0.0/0 comment=UDM \
    endpoint-address=XX.XXX.XX.XX endpoint-port=62930 interface=WG1 \
    public-key="UDM_WG_Server_Public_Key"
add address=10.0.0.1/24 interface=br-local network=10.0.0.0
add address=192.168.50.5 interface=WG1 network=192.168.50.5
/ip dhcp-client
add interface=ether1
add address=10.0.0.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.0.0.1
/ip firewall mangle
add action=change-mss chain=forward new-mss=clamp-to-pmtu out-interface=WG1 \
    passthrough=yes protocol=tcp tcp-flags=syn
add action=masquerade chain=srcnat out-interface=WG1
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=WG1 pref-src="" \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/system clock
set time-zone-name=Europe/Madrid
/system note
set show-at-login=no
I can surf Internet.
If I’m pinging with the 10.0.0.1 addresses, it works fine as well if I’m using 192.168.50.5
https://ibb.co/dKczdZY
If I activate the following Route, I can’t surf anymore.
https://imgbb.com/gDSWFM2
Any help on what I’m missing/doing wrong?
EDIT: I forgot that I aim to route all the traffic via the WG, so the IP shown will be from my house.
Where is the WG located.
We are assuming its not at your house, so where is it??
This is incorrect.
public-key=“UDM_WG_Server_Public_Key”
What is the purpose of the entry of allowed peers!! Clearly you are just writing numbers down without any knowledge.
https://forum.mikrotik.com/viewtopic.php?t=182340
Also on the HAPAC peer line for the UDM server, you must have persistent-keep-alive set to say 35s.
Hi anav,
thanks for your reply.
The UDM is located at my house, while at the moment I’m abroad.
I will have a look at the thread you quote, but I thought that, in mikrotik, the peer section is also use to connect to the wireguard server.
But maybe I’ll find the answer in the thread.
On UDM I don’t see a persistent-keep-alive value to set
I tried again (and again) following your post.
In the end, there was always the same issue. Whenever I try to add the route
dst-address=0.0.0.0/0 gwy=wg-interface-name table=use-WG
I cannot surf anymore.
I reset the configuration. From scratch I
  • Setup DHCP Client on ether1
  • Create the bridge interface
  • Setup IP to bridge interface
  • Setup the DHCP Server on the bridge interface
  • Input the masquerade rule
I can surf, but when I try to ping the public IP of the WG_Server, from both the Mikrotik and the Macbook terminal, I get a timeout response.
The strange thing is that if I connect the Macbook to the WG_Server using the WG app, it connects, and then I can ping the public IP of the server (only from the Macbook).
This is the actual setup:
CLIENT
ISP Router —> Mikrotik hAPac2 —> Macbook
SERVER (ISP Fiber cable connects directly to the UDM Pro)
UDM Pro hosting the WG server
Not sure the reason why I can’t ping the server
I understand you have a UDM router at home and this device has wireguard Server instance.
You also have a hapac2 but where is it located??
Assuming you have some sort of connection to the internet wherever you use it either from a wifi at hotel or plugged in matters little.
As stated you have a wireguard client setup on the router to phone UDM home.
I will repeat myself,
For the allowed Peers on the MT client device this is wrong!!
Tell me what you hope to accomplish with the allowed peers you have chosen!! Explain it in words!!
Yes it needs persistent-keep-alive setting on the hapac2, and specifically on the peer setttings above for the UDM.
For sourcenat you need
FOR IP route you need
add dst-address=0.0.0.0/0 gateway=ether1-gatewayIP routing-table=main
add dst-address=0.0.0.0/0 gateway=WG1 routing-table=useWG
NOW set a fixed static lease on your macbook or PC to an IP of 10.0.0.5/32 (wired for example) and a different one for wifi so you could access local WAN for ex.
Add A table and a Routing Rule
/routing table add fib name=useWG
/routing rule add src-address=10.0.0.5/32 action=lookup table=useWG
The idea being you need to connect to the regular internet and IP route, to create the tunnel and then you want one use to go through the tunnel.
I connect the MT to whatever network I found while traveling.
In this case, it’s wired connected to a Movistar (Spanish ISP) modern/router
For the allowed Peers on the MT client device > this is wrong!!
Tell me what you hope to accomplish with the allowed peers you have chosen!! > Explain it in words!!
My only aim is to driven all the traffic via the wireguard interface. I changed it to 0.0.0.0/0
I tried with the IP I set for the bridge interface, but when I add this
I now can see the WG is connecting (last handshake value starts counting), but goes back to zero every 5 second
But I don’t understand why if I ping my UDM I can’t get an answer, while if I’m connecting using the Wireguard app via that Macbook it connects w/o problem.
Also, is it normal for the last handshake timer to reset every 5/6 seconds? (video below)
https://jumpshare.com/s/Pg4GpbPjBmNlKxFYucJw
