I’ve two CCR1036 using the RouterOS 6.32.3 with last firmware. They are connected by optic fiber and running OSPF.
Sometimes I’ve problems on the OSPF and it stops to work for a short period.
The RouterOS logs these informations:
01:07:52 route,ospf,info Database Description packet has init bit set in middle of an exchange
01:07:52 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Full to 2-Way
01:08:43 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Full to Init
01:08:49 route,ospf,info Database Description packet has init bit set in middle of an exchange
01:08:49 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:09:29 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:09:47 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:09:59 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from ExStart to Down
01:10:00 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from ExStart to Down
01:10:20 route,ospf,info Discarding packet: no neighbor with this source address
01:10:20 route,ospf,info RouterId=10.99.99.12
01:10:20 route,ospf,info source=10.100.101.26
01:10:20 route,ospf,info source=10.100.100.26
01:11:02 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:07 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:44 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:48 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:11:57 route,ospf,info Database Description packet has init bit set in middle of an exchange
01:11:57 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
01:12:54 route,ospf,info OSPFv2 neighbor 10.99.99.12: state change from Exchange to 2-Way
OSPF configuration on Router 1:
/ip address> print
# ADDRESS NETWORK INTERFACE
0 10.100.101.25/30 10.100.101.0 ether11
1 10.100.100.25/30 10.100.100.0 sfp3
2 10.99.99.2/32 10.99.99.2 lobridge
/routing ospf instance> print
Flags: X - disabled, * - default
0 * name="default" router-id=10.99.99.2 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
metric-default=1 metric-connected=20 metric-static=20 metric-rip=20 metric-bgp=auto metric-other-ospf=auto in-filter=ospf-in out-filter=ospf-out
/routing ospf interface> print
Flags: X - disabled, I - inactive, D - dynamic, P - passive
# INTERFACE COST PRIORITY NETWORK-TYPE AUTHENTICATION AUTHENTICATION-KEY
0 sfp3 10 1 point-to-point none
1 ether11 30 1 point-to-point none
/routing ospf network> print
# NETWORK AREA
0 10.100.100.24/30 backbone
1 10.100.101.24/30 backbone
2 10.99.99.2/32 backbone
OSPF configuration on Router 2:
/ip address> print
0 10.100.101.26/30 10.100.101.0 sfp1
1 10.100.100.26/30 10.100.100.0 sfp2
2 10.99.99.12/32 10.99.99.12 lobridge
0 * name="default" router-id=10.99.99.12 distribute-default=never redistribute-connected=no redistribute-static=no redistribute-rip=no redistribute-bgp=no redistribute-other-ospf=no
0 sfp1 30 1 point-to-point none
1 sfp2 10 1 point-to-point none
# NETWORK AREA
2 10.99.99.12/32 backbone
Can someone help me?
