Issues with Ping between Wireguard and LAN
TL;DR - I can ping from Wireguard interface to remote LAN but i can’t ping from bridge interface (or any LAN interface) to remote LAN (see attachment)
I have a problem with ping between LAN interfaces (bridge, ether1,2…) and the WireGuard site-to-site VPN tunnel. I have two MikroTik routers connected via a WireGuard site-to-site VPN.
Ping between the routers is successful. (I can connect via SSH from MT2 to MT1 and from MT1 to MT2)
Ping from the router to the remote LAN network is successful. (from terminal MT2 I can ping device in LAN1)
Ping from the local LAN network (bridge, ether1,2…) to the remote LAN network is NOT successful.
Even ping from the local LAN network (bridge, ether1,2…) to the WireGuard tunnel is NOT successful.
Routing is configured. The firewall has been completely disabled for testing purposes.
Maybe I need to add NAT somewhere? I would greatly appreciate any ideas on what I can check to establish a connection from the LAN network to the VPN tunnel.
Model: MT hAP ac2
RouterOS: 7.15.3
