Hi to everyone! I can’t update. The latest working releases 6.46.6 and 6.47. During updating, the connection to the Internet disappears and every 5 seconds the connection to the RoS disappears too. Resetting does not help; after setting the parameters, the situation repeats. The logs are empty. When dumping, it first reports that it does not support the connection and you need to switch to Legacy Mode, but after a few seconds, it connects.
My config:
# model = 951Ui-2nD
add admin-mac=auto-mac=xx:xx:xx:xx:xx:xx no name=bridge
set [ find default-name=ether1 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether2 ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name=\
ether2
set [ find default-name=ether3 ] advertise=\
set [ find default-name=ether4-inet ] advertise=\
10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=xx:xx:xx:xx:xx:xx
name=ether4-inet
set [ find default-name=ether5 ] advertise=\
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
20/40mhz-Ce country=no_country_set disabled=no distance=indoors \
frequency=auto frequency-mode=manual-txpower mode=ap-bridge ssid=Wi-Fi \
wireless-protocol=802.11 wps-mode=disabled
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
set [ find default=yes ] authentication-types=wpa2-psk disable-pmkid=yes \
eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik \
wpa2-pre-shared-key=**********
/ip hotspot profile
/ip ipsec policy group
set [ find default=yes ] name="IPSec Group"
/ip ipsec profile
set [ find default=yes ] dh-group=modp1024 enc-algorithm=\
aes-256,aes-192,aes-128,3des
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
aes-256-cbc,aes-128-cbc,3des pfs-group=none
add name=default-dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=default-dhcp disabled=no interface=bridge lease-time=12h \
name=DHCP
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=ether2-master
add bridge=bridge interface=ether1
add bridge=bridge interface=ether3
add bridge=bridge interface=ether5
set discover-interface-list=discover
add interface=wlan1 list=discover
add interface=bridge list=discover
add interface=bridge list=mactel
add interface=bridge list=mac-winbox
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
/ip dhcp-client
add add-default-route=special-classless comment=defconf disabled=no \
interface=ether4-inet use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.1.2 client-id=xx:xx:xx:xx:xx:xx mac-address=\
xx:xx:xx:xx:xx:xx server=DHCP
add address=192.168.1.5 always-broadcast=yes client-id=xx:xx:xx:xx:xx:xx \
mac-address=xx:xx:xx:xx:xx:xx server=DHCP
add address=192.168.1.0/24 dns-server=10.0.1.1 gateway=192.168.1.1 netmask=24 \
ntp-server=192.168.1.1
set allow-remote-requests=yes servers=8.8.8.4,8.8.8.8
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip proxy
set always-from-cache=yes src-address=192.168.1.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.1.0/24 port=8080
set ssh address=192.168.1.0/24 disabled=yes
set api disabled=yes
set winbox address=192.168.1.0/24
set api-ssl disabled=yes
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=Home
/system logging
add topics=critical
add disabled=yes topics=debug
add disabled=yes topics=event
/system package update
set channel=long-term
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
add action=accept chain=input connection-state=established,related
add action=accept chain=input dst-port=1701 ipsec-policy=in,ipsec protocol=\
udp
add action=drop chain=input dst-port=1701 protocol=udp
add action=drop chain=input comment="drop all from WAN" \
in-interface=ether4-inet
"drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface=ether4-inet
add action=accept chain=forward comment="accept established,related" \
add action=accept chain=forward in-interface=bridge
add action=accept chain=forward out-interface=bridge
add action=drop chain=forward comment="drop invalid" \
connection-state=invalid log=yes log-prefix=DROP
out-interface=ether4-inet
