It does not work modem sierra mc 7710
The modem can not connect on LTE
What I tried:
  1. Firmware me, that’s the ones I’ve tried
    SWI9200x_03.00.08.02
    SWI9200x_03.05.23.02
    SWI9200X_03.05.29.03
  2. Changed operators
  3. Changed the antenna
  4. change the mode dip qmi
Screenshot of the problem, as well as attaching a file supout.rif.
In support of addressing, said that the pit is not supported. So I dip in and it does not work mode.
Please tell me what can be done?
There is also a modem QUECTEL EС 20 also could not make it work, I just have not tried. A sierra mc 7700 microns gained, obtained from 3 applications modems is only one … How else would make 7710 work.
Have you tried disabling LTE and using PPP to see if you can connect to the modem that way?
Via the supported hardware list: http://wiki.mikrotik.com/wiki/Supported_Hardware
Sierra Wireless MC7710/MC7700 [97] v5.25 and v6.0
If modem uses firmware 3.5 it should be upgraded to 3.5.23.2 firmware release in order to work in RouterOS correctly again.
Try upgrading to a newer firmware than 3.0?
