Good and Greetings Colleagues! I have a 750G with hotspot running with 54 subscribers, I have the ether 1 as Wan and all the rest of the Ether as a hotspot! I wanted to know if I can disable the dhcp of the Hotspot “only on a specific ether” so I can assign a static ip on the client’s device that depends on a wired network directly from the aforementioned port? If there is such a configuration, I would appreciate your help! Blessings…
Does he need the hotspot?
Or for him is enough direct connection?
Hi
I’m guessing all the interfaces are in a bridge, and the dhcp server is defined on that bridge. Then no.
If you really don’t want dhcp offers there, isolate the interface and assign it a different range, with no dhcp server for it.
There are two ways out:
- if that’s a particular device with known MAC address, you can make the DHCP lease static (and optionally edit the leased IP address)
- set IP address by hand on the device. In this case it won’t ask DHCP server for one.
