It's RB433 RouterOS or R5H card issue???
Good day…
Is anyone same like me, The said thing before March in the turbo mode with country: Uzbekistan
It can run on the following channel…
5210,5250,5255,5260,5265,5270,5275,5280,5285,5290,
5540,5545,5550,5555,5560,5565,5570,5575,5580,5585,5590,5595,
5600,5605,5610,5615,5620,5625,5630,5635,5640,5645,5650,5655,5660,
5760,5765,5770,5775,5780,5785,5790,5795,5800
But after March, in turbo mode with uzbekistan only can have <10 turbo channel.
Anywhere to recover it back or we can write the table manually???
use Brazil and you will be amazed :sunglasses:
I have tested, in the turbo mode, we are not able to use brazil for the country selection.
It show bad band or channel..
you will need superchannel to unlock all frequencies. ask your dealer, or email mikrotik
Hi Normis…
This thing only happened on the latest RB433 and the R5H…
before this we are able to use all the said channel…
I don;t think so it’s due to the super channel..
and we also found the R5H TX power is from previous 21dbm to 25dbm …now become from 20dbm to 24dbm.
What’s going on this?
Hi Normis,
i take the superchannel license, but i can’t use more freq’s than 5 in supechannelmode/no_country.
only 5210,5250,5290,5760,5800. My board is RB433AH, with 2 chipsets R5H and XR5.
P.S. Note, that everything fine work with XR5, but not with R5H
set wireless mode to “superchannel” and then do “/wireless info print” what do you see there?
Sorry,
i find my problem. I must use the scan list, without scan list it take the default freqs of band :wink:
:laughing: Now everything work very fine.
