I need help to initially configure the O.S. to get my system up and running as soon as possible;
1- need to setup a hotspot
2- need to setup users
3- need to setup BW restrictions.
Thanks.
Thanks.
first make sure the internet works without any of these features (check that you have an IP, route, that user can access the internet).
then:
Thanks, I am very new to this, I can not get the internet to go through the router, what I really need at this stage is a step by step writeup or script to get the system working with the very basic minimum setup.
Can any one assist please.
Thank you.
Set your routerboard eth0 ip subnet/netmask/gateway thru serial terminal (hyperterminal), connect ethernet cable from pc/laptop to eth0, set pc/laptop ethernet to same subnet then winbox into routerboard to set up your wireless interface(s), firewall , etc,etc…
