Javascript for Hotspot users logout.html
Hi all
I need some help to get final MB left for hotspot users
So far I use the following variables
$(limit-bytes-total) --> available Bytes when last logged on
$(bytes-total) ---> used Bytes during session
I now would like to show the user the actual Bytes left
$(limit-bytes-total) subtract $(bytes-total) equals actual Bytes left.
I am just lost how to archive that with java script.
Thanks a lot for your help!
Mat
Ok, there the solution:
Total Megabytes Left: Data Traffic Used Since Last Logon:
or full website example
XX Wireless - Status Information
$(if refresh-timeout)
$(endif)
textarea,input,select { background-color: #C0C0C0; border: 4px #BBBBBB solid; padding: 3px; margin: 10px; font-size: 12px; color: black; } .tabula{ border-width: 0px; border-collapse: collapse; border-color: #c1c1c1; background-color: transparent; font-family: verdana; font-size: 14px; } body{font-size: 3px; font-family: verdana; } \ \ a, a:link, a:visited, a:active { color: #AAAAAA; text-decoration: none; font-size: 12px; } a:hover { border-bottom: 1px dotted #c1c1c1; color: #AAAAAA; } img {border: none;} td { font-size: 13px; padding: 4px;}
We recommend to keep this webpage open for your reference!
You are successfully logged on.
You are now able to access the internet. Enjoy your browsing.
$(endif)
Hi swissiws
Thanks for your help… :smiley:
