Jirous JRC-24 EXTREME
I have +20 links with jrc24extreme and duplex versions and they are awsome.
Ex.: 12km link 10dBm tx-power i get -72dBm signal.
Looks like you have a damaged pigtail or radio card or cable. To debug these links i use a groove pluged directly to the antenna.
That is why we gather in this forum! :slight_smile: Wonderful idea, I’ll try it out as soon as possible.
yes there is no way to be signal like that…if you have clear LOS. So the groove is best way to test it…we use mostly jirous antennas…till now no problem(knock, knock:D)
hello to all
bad english sorry
i have PtP link with rb411 and R5H card and grid antena over 12km only works in 20 Mhz when i switch to 40 mhz turbo mode is not working keeps connect and disconnect . Nstream is ON and etc…
in normal mode 5ghz thrououtput is about 30 Mbs/s
can enyone tell me what could be wrong or something …
coz in normal mode is working fine with -53/-59 signal
bye
What is the relation to the topic ? You have to set both sides in the same way…
