Join to sites with SXT devices
I have 2 sites with a Mikrotik router and internet access. There are 1km far each other, I want to join both sites with SXT devices. Each site have it’s own network: 192.168.1.0/24 and 192.168.2.0/24
I read about how to do that but I see lots of modes: brigde, wps… Which one do you recommend?
I will really appreciate your help, this is my first time with wireless links.
Best regards.
Give the SXTs local addresses in the appropriate network - like .2
Create a transport network between the two wireless devices.
192.168.1.0/24 site:
On your site’s router add a route to the remote network with the SXT as gateway, i.e.:
add distance=10 dst-address=192.168.2.0/24 gateway=192.168.1.2
configure the SXT as AP with the follwing settings:
add address=192.168.1.2/24 interface=ether1
add address=172.16.0.1/30 interface=wlan1
add distance=10 dst-address=192.168.2.0/24 gateway=172.16.0.2
On the 192.168.2.0/24 site, add the other route via the SXT:
add distance=10 dst-address=192.168.1.0/24 gateway=192.168.2.2
Configure the SXT as Station and add these settings:
add address=192.168.2.2/24 interface=ether1
add address=172.16.0.2/30 interface=wlan1
add distance=10 dst-address=192.168.1.0/24 gateway=172.16.0.1
And off you go.
-Chris
